1 Reply Latest reply on Sep 16, 2013 9:43 AM by jcanepa
    When using the "Save as PDF" button
    TCK22
      When using the "Save as PDF" button/function on the "View Responses" page for a selected response will the resulting file be savable locally and printable on 8.5x11" paper?
      Also its Help bubble says that is savable as a PDF form. Does it really mean as a PDF file? Because saving it as a form appears to be a different option according to one pricing structure.
        • 1. Re: When using the "Save as PDF" button
          jcanepa Adobe Employee
          When you use the Save as PDF a pdf file if the form is created and saved to your local machine.  When you save as PDF you have the option of having the resulting pdf file have a submit button or not have the button.  There is also a feature where you can export the form to a template format called FCDT.
