7 Replies Latest reply on Sep 17, 2013 1:05 AM by gener7
    Cannot access 3D graphics in Photoshop CC
    dynchuck
      Hi, I have a macbook Pro, 17 in, with 8GB Ram, and the video card listed below.  It SEEMS to meet the specifications, but the 3D menu is not available in CC (it is available in PS CS-6, however).  Now, this laptop has the option of having "normal" graphics, or accellerated (which is what I listed below).  However, the first time I started Photohop CC, it was in Normal mode, and I recived a warning that the video driver was not fast enough.  I reset it to accellerated.  I no longer receive the error message, but the menu option is still not available.
      NVIDIA GeForce 9600M GT:
        Chipset Model:    NVIDIA GeForce 9600M GT
        Type:    GPU
        Bus:    PCIe
        PCIe Lane Width:    x16
        VRAM (Total):    512 MB
        Vendor:    NVIDIA (0x10de)
        Device ID:    0x0647
        Revision ID:    0x00a1
        ROM Revision:    3436
        gMux Version:    1.7.10
        Displays:
      Color LCD:
        Display Type:    LCD
        Resolution:    1920 x 1200
        Pixel Depth:    32-Bit Color (ARGB8888)
        Main Display:    Yes
        Mirror:    Off
        Online:    Yes
        Built-In:    Yes
        • 1. Re: Cannot access 3D graphics in Photoshop CC
          Level 7
          The Help->System Info log from Photoshop should provide more information.
          Most likely the dual GPU drivers are causing problems. In some systems, you have to disable the automatic GPU switching to use the more powerful GPU correctly.
          • 2. Re: Cannot access 3D graphics in Photoshop CC
            dynchuck Level 1
            Here is the results of that (see below).
            There is no reliable way to diable switching, other than a new graphics card.  Considering that this is a macbook pro (17") that does not seem likely.
            Adobe Photoshop Version: 14.1.1 (14.1.1 20130910.r.415 2013/09/10:23:00:00) x64
            Operating System: Mac OS 10.8.4
            System architecture: Intel CPU Family:6, Model:23, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
            Physical processor count: 2
            Processor speed: 2660 MHz
            Built-in memory: 8192 MB
            Free memory: 4764 MB
            Memory available to Photoshop: 7353 MB
            Memory used by Photoshop: 70 %
            Image tile size: 128K
            Image cache levels: 4
            The GPU Sniffer crashed on 9/16/13 at 12:16:04 PM
            Display: 1
            Main Display
            Display Bounds: top=0, left=0, bottom=1200, right=1920
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Basic
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            NumGPUs=1
            gpu[0].OGLVersion="2.1"
            gpu[0].MemoryMB=512
            gpu[0].RectTextureSize=8192
            gpu[0].Renderer="NVIDIA GeForce 9600M GT OpenGL Engine"
            gpu[0].RendererID=16918028
            gpu[0].Vendor="NVIDIA Corporation"
            gpu[0].VendorID=4318
            gpu[0].HasNPOTSupport=1
            gpu[0].CompileProgramGLSL=1
            gpu[0].TestFrameBuffer=1
            Serial number: 90970029116307837771
            Application folder: /Applications/Adobe Photoshop CC/
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 465.0G, 389.9G free
            Required Plug-ins folder: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
            Primary Plug-ins folder: /Applications/Adobe Photoshop CC/Plug-ins/
            Installed components:
               adbeape.framework   adbeape   3.4.0.29366   0.1160850
               AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.30746   79.535742
               adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
               AdobeACE.framework   AdobeACE   2.20.02.31468   79.543790
               AdobeAGM.framework   AdobeAGM   4.30.24.31468   79.543790
               AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
               AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
               AdobeBIB.framework   AdobeBIB   1.2.03.31468   79.543790
               AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.543790
               AdobeCoolType.framework   AdobeCoolType   5.13.00.31468   79.543790
               AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
               AdobeExtendScript.framework   AdobeExtendScript   4.5.5.30746   79.535742
               AdobeJP2K.framework   AdobeJP2K   1.2.2.29712   79.248139
               AdobeLinguistic.framework      19061
               AdobeMPS.framework   AdobeMPS   5.8.1.30604   79.535029
               AdobeOwl.framework   AdobeOwl   5.0.13   79.533484
               AdobePDFL.framework   AdobePDFL   10.0.1.30505   79.499517
               AdobePDFSettings.framework   AdobePDFSettings   1.4
               AdobePIP.framework   AdobePIP   7.0.0.1786
               AdobeScCore.framework   AdobeScCore   4.5.5.30746   79.535742
               AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
               AdobeXMP.framework   AdobeXMPCore   79.151481   79.151481
               AdobeXMPFiles.framework   AdobeXMPFiles   79.151481   79.151481
               AdobeXMPScript.framework   AdobeXMPScript   79.151481   79.151481
               ahclient.framework   ahclient   1.8.0.31
               aif_core.framework   AdobeAIF   5.0.00   79.534508
               aif_ocl.framework   AdobeAIF   5.0.00   79.534508
               aif_ogl.framework   AdobeAIF   5.0.00   79.534508
               AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
               amtlib.framework   amtlib   7.0.0.169
               boost_date_time.framework   boost_date_time   7.0.0.0
               boost_signals.framework   boost_signals   7.0.0.0
               boost_system.framework   boost_system   7.0.0.0
               boost_threads.framework   boost_threads   7.0.0.0
               Cg.framework   NVIDIA Cg
               CIT.framework   CIT   2.1.6.30929   151865
               CITThreading.framework   CITThreading   2.1.6.30929   151865
               dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
               dvacore.framework   dvacore   7.0.0.0
               dvamarshal.framework   dvamarshal   7.0.0.0
               dvamediatypes.framework   dvamediatypes   7.0.0.0
               dvaplayer.framework   dvaplayer   7.0.0.0
               dvatransport.framework   dvatransport   7.0.0.0
               dvaunittesting.framework   dvaunittesting   7.0.0.0
               dynamiclink.framework   dynamiclink   7.0.0.0
               FileInfo.framework   FileInfo   79.151561   79.151561
               filter_graph.framework   AdobeAIF   5.0.00   79.534508
               ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
               ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
               LogSession.framework   LogSession   2.1.2.1785
               mediacoreif.framework   mediacoreif   7.0.0.0
               patchmatch.framework   patchmatch   1.2.00.31297   79.542390
               PlugPlugOwl.framework   PlugPlugOwl   4.0.1.34
               UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
               WRServices.framework
            Required plug-ins:
               3D Studio 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Accented Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Adaptive Wide Angle 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
               Angled Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Average 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Average.plugin”
               Bas Relief 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               BMP 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Camera Raw 8.1 (43), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Camera Raw Filter 8.1 (43), Copyright © 2013 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
               Chalk & Charcoal 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Chrome 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Cineon 14.1.1 x001  ©2002-2013 Adobe Systems Incorporated - from the file “Cineon.plugin”
               Clouds 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Collada DAE 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Color Halftone 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Colored Pencil 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               CompuServe GIF 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Conté Crayon 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Craquelure 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crop and Straighten Photos 14.1.1 x001  ©2003-2013 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
               Crop and Straighten Photos Filter 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Crosshatch 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Crystallize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Cutout 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Dark Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               De-Interlace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dicom 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “dicom.plugin”
               Difference Clouds 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Clouds.plugin”
               Diffuse Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Displace 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Dry Brush 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Eazel Acquire 14.1.1 x001  ©1997-2013 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
               Embed Watermark NO VERSION - from the file “DigiSign.plugin”
               Entropy 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Extrude 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               FastCore Routines 14.1.1 x001  ©1990-2013 Adobe Systems Incorporated - from the file “FastCore.plugin”
               Fibers 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Film Grain 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Filter Gallery 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Flash 3D 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Fresco 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Glowing Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Google Earth 4 KMZ 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Graphic Pen 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Halftone Pattern 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               HDRMergeUI 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
               IFF Format 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Ink Outlines 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               JPEG 2000 14.1.1 x001  ©2001-2013 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
               Kurtosis 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Lens Blur 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
               Lens Correction 14.0, Copyright © 2002-2013 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
               Lens Flare 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Liquify 14.0, Copyright © 2001-2013 Adobe Systems Incorporated - from the file “Liquify.plugin”
               Matlab Operation 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Maximum 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mean 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Measurement Core 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
               Median 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Mezzotint 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Minimum 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               MMXCore Routines 14.1.1 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MMXCore.plugin”
               Mosaic Tiles 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Multiprocessor Support 14.1.1 x001  ©1990-2013 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
               Neon Glow 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Note Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               NTSC Colors 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
               Ocean Ripple 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Oil Paint 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
               OpenEXR 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Paint Daubs 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Palette Knife 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Patchwork 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Paths to Illustrator 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               PCX 14.1.1 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PCX.plugin”
               Photocopy 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Photoshop 3D Engine 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
               Photoshop Touch CC (14.0.0.0) ©1993-2013 Adobe Systems Incorporated - from the file “PSDX.plugin”
               Picture Package Filter 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
               Pinch 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pixar 14.1.1 x001  ©1989-2013 Adobe Systems Incorporated - from the file “Pixar.plugin”
               Plaster 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Plastic Wrap 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               PNG 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Pointillize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Polar Coordinates 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Portable Bit Map 14.1.1 x001  ©1989-2013 Adobe Systems Incorporated - from the file “PBM.plugin”
               Poster Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Radial Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Radiance 14.1.1 x001  ©2003-2013 Adobe Systems Incorporated - from the file “Radiance.plugin”
               Range 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Read Watermark NO VERSION - from the file “DigiRead.plugin”
               Reticulation 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Ripple 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Rough Pastels 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Save for Web 14.0, Copyright © 1999-2013 Adobe Systems Incorporated - from the file “Save for Web.plugin”
               ScriptingSupport 13.0, Copyright © 2013 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
               Shake Reduction 14.0, Copyright © 2013 Adobe Systems Incorporated - from the file “Shake Reduction.plugin”
               Shear 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Skewness 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Smart Blur 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Smudge Stick 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Solarize 14.1.1 x001  ©1993-2013 Adobe Systems Incorporated - from the file “Solarize.plugin”
               Spatter 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Spherize 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Sponge 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Sprayed Strokes 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stained Glass 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Stamp 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Standard Deviation 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               STL 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Sumi-e 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Summation 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Targa 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Texturizer 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Tiles 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Torn Edges 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Twirl 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Underpainting 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Vanishing Point 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
               Variance 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “statistics.plugin”
               Water Paper 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Watercolor 14.0, Copyright © 1991-2013 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
               Wave 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wavefront|OBJ 14.1.1 x001  ©2006-2013 Adobe Systems Incorporated - from the file “U3D.plugin”
               Wind 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
               Wireless Bitmap 14.1.1 x001  ©1989-2013 Adobe Systems Incorporated - from the file “WBMP.plugin”
               ZigZag 14.0, Copyright © 2003-2013 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
            Optional and third party plug-ins: NONE
            Plug-ins that failed to load: NONE
            Flash:
               Kuler
               Adobe Exchange
            Installed TWAIN devices: NONE
            • 3. Re: Cannot access 3D graphics in Photoshop CC
              Level 7
              Your driver has a serious bug in it. Make sure you have updated it from NVidia's website.
              • 4. Re: Cannot access 3D graphics in Photoshop CC
                dynchuck Level 1
                Wow, that is useless.  But I have learned to expect that from Adobe.
                This is a MAC laptop.  There are no viable Nvidia drivers for it.  Nvidia drivers are only for Window's computer.  If there is an update it has to come from Apple.
                So yet again, yet another Adobe product fails.  I pay $50 a month for Shoddy products.
                • 5. Re: Cannot access 3D graphics in Photoshop CC
                  SG... Adobe Employee
                  Take a look at post #21 in this thread:
                  http://forums.adobe.com/message/5686719#5686719
                  Send Kevin email as he would like to work with you and figure out the driver issues.
                  regards,
                  steve
                  • 6. Re: Cannot access 3D graphics in Photoshop CC
                    Level 7
                    Actually, NVida publishes updated drivers for many of their cards on MacOS as well...
                    • 7. Re: Cannot access 3D graphics in Photoshop CC
                      gener7 Adobe Community Professional & MVP
                      MacOS 10.8.5 is out if anyone is interested. Just run Software Update.
                      Gene
