3 Replies Latest reply on Sep 18, 2013 12:37 PM by Matinciel
    Auto trace using only 17% of CPU and slowing down
    Matinciel
      Hi there,
      So I got a sequence with a keylight effect, then I want to use auto-trace function.
      The source is a 1080p mp4 but the effect is applied on about a quarter of the surface (that's to say I use a mask to cover the area I don't want to process)
      The length is about 16 minutes.
      Everything start smoothly frames are processed quiet well maybe 10 every 5 seconds and then it slows up after about three hours of processing I got maybe one frame per 5 seconds.
      I've activated multriprocessing with 3 GB reserved for other programs. 1.5GB per core, it says 7 cores will be used.
      You could refer screen capture below for CPU / Memory / Disk usage
      My computer is :
      CPU intel core I7 2600k
      Asus p8z68-v pro/gen3
      4x4 G.Skill F3-12800CL9D-8GBSR1 - Mémoire SNIPER Series -  Dual Channel - DDR3-1600 (PC3 12800)  - 9-9-9-24-2N - 1.35V
      GPU Asus GTX 670
      After Effets CC
      Any idea why it is so slow ? Should I get 32GB of RAM as it seems to be limiting my cpu ? Any way to use GPU instead ?
      Thanks a lot for any advices !
      CPU :
      Memory :
      Disks :
        • 1. Re: Auto trace using only 17% of CPU and slowing down
          Dave LaRonde Level 6
          MP4's aren't the most AE-friendly files on the planet.  What happens if you transcode to a lossless codec like a QT in PNG, or pehaps in DNxHD?
          • 2. Re: Auto trace using only 17% of CPU and slowing down
            Todd_Kopriva Level 8
            No.
            That is not relevant for Auto-trace. The Auto-trace process is not a rendering process, so it's not going to be aided by the Render Multiple Frames Simultaneously multiprocessing feature.
            You're exhausting the RAM in the system and likely swapping the contents of RAM to the hard disk, which is a real performance killer.
            Process the video in smaller pieces. 16 minutes is a long video.
            • 3. Re: Auto trace using only 17% of CPU and slowing down
              Matinciel Level 1
              Thanks, I wasn't aware of this. I've reencoded my video to quick time and then render in AE => 30 minutes...
              As proposed by Todd, I've cut the size of my project in two sequence that's help a bit.
