4 Replies Latest reply on Sep 17, 2013 1:35 AM by Sathya Rani M
    Reg.Apply paragraph style
    Sathya Rani M
      Hi All,
      Can you please anybody help me that how to apply the paragraph style which is available in Indesign with case insensitive in find/change grep options.
      I have tried with below code but the style applying only with case sensitive.
                myStyleName = myString.substring(1, myString.length-1);
                  if(myDocument.paragraphStyles.item(myStyleName) == "[object ParagraphStyle]")
                      myStyle = myDocument.paragraphStyles.item(myStyleName);
                      myName = myStyle.name;
                      app.findChangeTextOptions.caseSensitive = false;
                      app.changeTextPreferences.appliedParagraphStyle = myStyle;
                      myDocument.changeText();
                      app.changeTextPreferences = NothingEnum.nothing;
                      app.changeTextPreferences.changeTo = "";
      Please help me to figure out this issue.
      Thanks in advance.
      Regards,
      Sathya Rani M
        • 1. Re: Reg.Apply paragraph style
          Jump_Over Level 5
          Your code in current version makes one go cross-eyed.
          - you are looking for find/change grep options but code is setting find/change text options;
          - where is yours "findWhat" set?
          - you can't execute changeText() (even twice...) with findWhat omitted;
          - what exactly case sensitive is according to?
          Be more accuracy, pls.
          Jarek
          • 2. Re: Reg.Apply paragraph style
            Sathya Rani M Level 1
            Hi Jarek,
            Thank you for your reply. Actually I need to find the style name with tag from activeDocument.
            For eq. if <lrh> or <LRH> found in activeDocument then find the "lrh" style available in Indesign and apply.
            Here is my full code. Please look into it.
            var myDocument = app.activeDocument;
            var myDocument = app.documents.item(0);
            app.findGrepPreferences = NothingEnum.nothing;
            app.changeGrepPreferences = NothingEnum.nothing;
            app.findGrepPreferences.findWhat = "(?i)^<\\s*\\w+\\s*>";
            var myFoundItems = myDocument.findGrep();
            if(myFoundItems.length != 0)
                    var myFoundTags = new Array;
                    for(var myCounter = 0; myCounter<myFoundItems.length; myCounter++)
                        myFoundTags.push(myFoundItems[myCounter].contents);
                    for(var i = 0; i < myFoundTags.length; i++)
                        myString = myFoundTags[i];
                        app.findTextPreferences.findWhat = myString;
                            app.findChangeTextOptions.includeFootnotes = false;
                            app.findChangeTextOptions.includeHiddenLayers = false;
                            app.findChangeTextOptions.includeLockedLayersForFind = false;
                            app.findChangeTextOptions.includeLockedStoriesForFind = false;
                            app.findChangeTextOptions.includeMasterPages = false;
                            app.findChangeTextOptions.wholeWord = false;
            But it is applying style only if "lrh" is present. It should be find case insensitive. please help me out.
            Thank you.
            ~Sathya Rani M
            • 3. Re: Reg.Apply paragraph style
              Jump_Over Level 5
              it is finding case insensitive but after this is trying to match a para style name with "findWhat" string (which vary).
              Is your style names always lowercase?
              If yes modify:
              myStyleName = myString.substring(1, myString.length-1).toLowerCase();
              Jarek
              • 4. Re: Reg.Apply paragraph style
                Hi Jarek,
                The suggested case working is fine. I have solved the issue by treating the style names with Uppercase as you saying in lowercase.
                Thank you very much for your support!
                ~Sathya Rani M
