0 Replies Latest reply on Sep 17, 2013 8:19 AM by Nuttanunt Chinthawon
    How to export files (e.g. .mov .avi .mp4 .mpg .mpeg etc.) to XDCAM EX 35 MPEG 4 QuickTime file
      How to export files (e.g. .mov .avi .mp4 .mpg .mpeg etc.) to XDCAM EX 35 MPEG 4 QuickTime file with Adobe Premier Pro CC
      Sep 5, 2013 2:31 PM
      Tags: none (add)
      To Support Team
      I use Premiere Pro CC from Adobe creative cloud.
      I have all footage files format (e.g. .mov .avi .mp4 .mpeg .mpg  etc.) to use in my project.
      “How to export files to XDCAM EX 35 MPEG 4 QuickTime file with Adobe creative cloud Premiere Pro CC ?”
      What is program to use? or
      What is plugin to use? or
      How to set sequence ? or etc.
      Thank you very much.
      Best Regards
      N. Chinthawon
      Bangkok
      Thailand
      e.g.
      Format                                   : MPEG-4
      Commercial name                          : XDCAM EX 35
      Format profile                           : QuickTime
      Codec ID                                 : qt
      File size                                : 50.9 MiB
      Duration                                 : 15s 0ms
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 28.5 Mbps
      Encoded date                             : UTC 2013-06-18 10:04:37
      Tagged date                              : UTC 2013-06-18 10:04:38
      Writing library                          : Apple QuickTime
      Media/UUID                               : A185EBC7-7ACA-4F9A-B537-D52733598430
      Video
      Format                                   : MPEG Video
      Format version                           : Version 2
      Format profile                           : Main@High
      Format settings, BVOP                    : Yes
      Format settings, Matrix                  : Custom
      Format settings, GOP                     : M=3, N=12
      Codec ID                                 : xdvc
      Duration                                 : 15s 0ms
      Bit rate mode                            : Variable
      Bit rate                                 : 26.9 Mbps
      Maximum bit rate                         : 35.0 Mbps
      Width                                    : 1 888 pixels
      Original width                           : 1 920 pixels
      Height                                   : 1 062 pixels
      Original height                          : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate mode                          : Constant
      Frame rate                               : 25.000 fps
      Standard                                 : Component
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Interlaced
      Scan order                               : Top Field First
      Compression mode                         : Lossy
      Bits/(Pixel*Frame)                       : 0.537
      Time code of first frame                 : 00:00:00:00
      Time code source                         : Group of pictures header
      Stream size                              : 48.2 MiB (95%)
      Language                                 : English
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
      Audio
      Format                                   : PCM
      Format settings, Endianness              : Little
      Format settings, Sign                    : Signed
      Codec ID                                 : sowt
      Duration                                 : 15s 0ms
      Bit rate mode                            : Constant
      Bit rate                                 : 1 536 Kbps
      Channel(s)                               : 2 channels
      Channel positions                        : Front: L R
      Sampling rate                            : 48.0 KHz
      Bit depth                                : 16 bits
      Stream size                              : 2.75 MiB (5%)
      Language                                 : English
      Other
      Type                                     : Time code
      Format                                   : QuickTime TC
      Duration                                 : 15s 0ms
      Time code of first frame                 : 00:00:13:15
      Time code settings                       : Striped
      Language                                 : English
      Encoded date                             : UTC 2013-06-18 10:04:38
