0 Replies Latest reply on Sep 17, 2013 9:37 AM by Karl Z
    Grep Styles - Conflicting - "^" not working in lookbehind and more
    Karl Z
      Still fighting my way in the jungle of paragraph grep styles.
      In InDesign CS5 by the way.
      I import text from DB and they all come in the same.
      I need to use the same paragraph style to all paragraphs.
      I really don't want to use find-change since that would mess up the xml holding the data.
      Example-text explanation:
      • All sizes are separated by ", - "
      • …… = tab
      • Not all rows have tab
      • Sizes can be both numeric, letters, contain "/" and "-" and """ and " " (space) and yes indeed a "," comma!! (and every other idiotic combination you culd think of.)
      • When only 2 posts in a row - should be separated by a ", " = (Comma-space)
      • When more than 2 posts i a row - all posts but first and last should be hidden and separated by " - " (space-dash-space)
      I have tried numerous combinations to get them all but they always conflict with each other.
      Bugger!
      I really shouldn't be impossible.
      Is it possible in Paragraph grep styles to "catch" "any character but these" and kind of make a character-set like [!not this character]   (= [!a|b|c]  )
      Is it possible to count the number of posts in a row? ( like... if more than 2 then hide...bla bla)
      All sizes are separated by the same ", - " and sometimes I want to hide them, and somtimes I want to use one of them...
      Is there any kind of "if-else" thing that can be used??
      My original idea was to be able to catch them by using ^-combinations for beginning of paragraph and matching with tha linebreak and tab but it seems as if that don't always work when using positive or negative look-behind-ahead.
      Oh, I'm blabbering. Sorry.
      Any hints or pointers would be greatly appreciated.
      /K
      A) Got this - Original textSame text but this is my Goal!
      134/140, - 146/152, - 158/164……….299,-
      134/140, - 146/152……….299,-
      38, - 40, - 42, - 44, - 46……….399,-
      38, - 40……….399,-
      XS, - S, - M, - L, - XL……….399,-
      XS, - S, - M, - L
      XS, - M
      B 70, - 75, - 80, - 90, - 95……….199,-
      B 70, - 75……….199,-
      Medium-Wide 17”, - 17,5”……….995,-
      Normal, - X-Wide……….999,-
      16 mm 95, - 105, - 115, - 125, - 135, - 145…......99,-
      16 mm 95, - 105……....99,-
      134/140 - 158/164……….299,-
      134/140, 146/152……….299,-
      38 - 46……….399,-
      38, 40……….399,-
      XS - XL……….399,-
      XS - L
      XS, M
      XS - XL……….399,-
      B 70 - 95……….199,-
      B 70, 75……….199,-
      Medium-Wide 17”, 17,5”……….995,-
      Normal, X-Wide……….999,-
      16 mm 95 - 145…......99,-
      16 mm 95, 105……....99,-
      GrepStyleResult wanted
      ,\s(?<=,\s)-\s.+(?=\s-)
      Red undelined text will be hidden
      (Got this)
      38, - 40……….399,-
      XS, - S, - M, - L
      XS, - M
      B 70, - 75……….199,-
      Need this to not conflict with other grep
      blue underlined text needs to be hidden.
      38, - 40……….399,-
      XS, - S, - M, - L
      XS, - M
      B 70, - 75……….199,-
