4 Replies Latest reply on Sep 19, 2013 7:56 AM by Prails.deisgn
    Biggest pathItem in a document
    Prails.deisgn Level 1
      Hey Guys,
      I have a  question that I've been toying with for awhile, is there a way to determine the biggest item in a document using javascript? I haven't even seen anything on it before and I can't find anyhting on it.
        • 1. Re: Biggest pathItem in a document
          CarlosCanto Adobe Community Professional & MVP
          probably nobody has had the need before, try this
          - get first pathItem
          - get its length
          - mark it as the the biggest
          - get next pathItem
          - get its length
          - compare its length against "the biggest"
          - if bigger, mark it as the biggest, if not ignore it
          - continue checking all paths
          • 2. Re: Biggest pathItem in a document
            Hey Carlos,
            I'm having a tough time with this one, here's what I have so far.
            #target illustrator
            var doc = app.activeDocument
            var pathCount
            var theBiggest
            pathCount=doc.pathItems.length
            for (i= 0; pathCount>i;i++){
                thBiggest=doc.pathItems[0]
                if (doc.pathItems[i].length > theBiggest) {
                doc.pathItems[i] = theBiggest
                else if (doc.pathItems[i].length < theBiggest) {
                   i++
                theBiggest.selected = true;
            • 3. Re: Biggest pathItem in a document
              you were close, in your loop you're marking theBiggest as the first path, you need to take that line outside the loop, so theBiggest gets changed
              you also have a typo in that same line, thBiggest <- missing an "e"
              here's a modified working version
              var doc = app.activeDocument;
              var pathCount = doc.pathItems.length;
              var theBiggest = doc.pathItems[0];
              for (i=1; i<pathCount; i++) {
                  if (doc.pathItems[i].length > theBiggest.length) {
                      theBiggest = doc.pathItems[i];
              • 4. Re: Biggest pathItem in a document
                Ah duh!
                Ya that totally makes sense now.
                Thanks Carlos
