0 Replies Latest reply on Sep 18, 2013 2:52 AM by bastieneichenberger
    problem CS5 - CS6, link.filePath
    bastieneichenberger Level 1
      Hi all,
      I wrote a script who works on max os x and CS6, CS5.5 version.
      But this same script doesn't work on CS5 and I don't know why.
      I think it's maybe because the filePath isn't not the same. It's maybe an encoding probem Not the first time for me!
      Can someone help me?
      #target indesign
      var my_doc = app.activeDocument;
      var array_links_item = my_doc.links;
      // get all links
      try{
          for(var i=0; i < array_links_item.length; i++){
              alert(has_item_alpha_channel (array_links_item[i]) );
      catch(ex){
          alert(ex.message);
      * function to check if an image contains alpha channel, this function run an AppleScript to call the shell (sips -g hasAlpha function)
      * @param {Link} link_item
      * @return {Boolean} true if the image contains an alpha channel
      * @throws {Error} if the system is windows, the function works only on mac os x
      function has_item_alpha_channel(link_item){
          if(File.fs == "Windows"){
              throw new Error("the function has_alpha_channel works only on mac os x");
          // replace all : to /
          var file_path = replaceAll (":", "/", link_item.filePath);
          // remove Macintosh HD from path
          file_path = file_path.replace("Macintosh HD", "");
          var appleScript = "set result to do shell script \"sips -g hasAlpha '"+  file_path +"'\"";
          var result = app.doScript(appleScript, ScriptLanguage.applescriptLanguage);
          var res = result.match("hasAlpha: yes");
          if(res != null){
              res = true;
          else{
              res = false;
          return res;
      function replaceAll(find, replace, str) {
        return str.replace(new RegExp(find, 'g'), replace);
