0 Replies Latest reply on Sep 18, 2013 7:47 AM by ibegabe
    Changing sample rates for recorded audio?
    ibegabe
      I've been trying to record VO through premiere. I'm using an m-audio mobile pre which has never given me trouble in any other application. When i turn on Meter Input(s) Only from the panel menu of the track mixer i can clearly see the input move in time and responsively. When I record however the resulting clip is much shorter than the ammount of time recorded and the audio is all garbled and chopped. It clearly jumps out to me as a sample rate problem. I looked at the clips and they are 44.1 but the sequence i'm recording to is 48. I made a 44.1 sequence and recorded to that which worked fine but there must be a way to change the recording sample rate right? I can't find a solution anywhere. Anybody know?
