4 Replies Latest reply on Jan 10, 2008 7:56 AM by gtrufitt
    Tweening with lingo
    gtrufitt Level 1
      I have a sprite that I need to tween from one location to another but I am not sure how to do it, below is the lingo that I have used but this causes the sprite to jump from one location to the needed location without tweening smoothly. Is there a way to tween it smoothly with lingo or would I have to find another way?
      if (_key.keyPressed(126)) then
      repeat while (timmy.locV > 337)
      timmy.locV = timmy.locV - 1
      end repeat
      end if
      end
      Thanks, Gareth
      Also - How do you write an if.. then statement that does
      if(condition) AND (condition) AND (condition) then
      So that something is done if all conditions are met?
      Gareth
        • 1. Re: Tweening with lingo
          Level 7
          Just let it happen in the normal flow of Director's events:
          on enterFrame
          if (timmy.locV > 337) then
          end if
          end if
          end enterFrame
          Andrew
          • 2. Re: Tweening with lingo
            Chunick Level 3
            quote:
            Originally posted by: gtrufitt
            end repeat
            end if
            end
            Here's a good link on tweening:
            http://www.jmckell.com/parametric.html
            start there and read on for some really good information and examples
            As for your second question; you actually answered it yourself, ie:
            if (condition) AND (condition) AND (condition) then
            -- code here
            end if
            -- that's exactly the syntax of it.
            • 3. Re: Tweening with lingo
              Lukewig Level 1
              Hi
              The following code wont really work:
              end repeat
              because inside the repeat loop, Director will not update the image buffer meaning that you wont see the animation. Either (a) put an updateStage call inside the repeat loop or (b) animate on enterframe or some other time-based event (such as Andrew's approach)
              Another trick to remember is to not use simple 1-px linear tweens but include some 'easing' - for example see lingoworkshop.com/downloads/examp74.dir
              -- Luke
              • 4. Re: Tweening with lingo
                gtrufitt Level 1
                Cheers for the help guys, i'll give it a go
                -Gareth
