4 Replies Latest reply on Sep 19, 2013 7:11 AM by rob day
    PDFX1a 2001  - WebNative has detected message appears?
    lister110 Level 1
      From within indesign CS5 I have to export HIRES pdf files using the above settings. But when I go to export the pdf I have a message appear
      'WebNative has detected that the Exported PDF not work with the PDF imaged Replacement worflow. Compatibility must be Acrobat 5 (PDF 1.4) or above and Stabdards Compliance must be none.'
      After exporting the file I'm seeing thin lines in the pdf file. I have turned off smooth art in acrobat which looks fine, but when dragged into PS the lines are there?
      Has anyone else seen this nessage before using PDFX1a 2001.
      lister
