3 Replies Latest reply on Sep 20, 2013 10:36 AM by iccsi
    SELECT Auto Complete
    iccsi Level 1
      I have a SELECT dropdown on the form and would like to have a function while user type then the dropdown will get the most close record for user to select.
      I tried to look on the internet, but no luck, It seems that CFSelect does not have this option.
      Any information is great appreciated,
      Regards,
      Iccsi,
        • 1. Re: SELECT Auto Complete
          Carl Von Stetten Adobe Community Professional & MVP
          Iccsi,
          AutoComplete widgets typically don't use SELECT elements; they usually build off of a standard text input box.  While I strongly discourage using <CFINPUT> (or any of the built-in ColdFusion UI tags), it does have an "autosuggest" attribute that triggers the type of behaviour you are looking for.  However, I would recommend looking at using jQueryUI's "autocomplete" widget, TwitterBootstrap's "typeahead" widget, or any number of other JavaScript/CSS AutoComplete solutions.
          HTH,
          -Carl V.
          • 2. Re: SELECT Auto Complete
            iccsi Level 1
            Thanks a million for the information and help,
            Regards,
            Iccsi,
            • 3. Re: SELECT Auto Complete
              iccsi Level 1
              I use jQuery auto complete, it works, but the font size it too big for my application. I tried to find the property to modify it, notr luck.
              I use CFQuery for the select output, the dropdown becomes slow, do I need use cfc function to get data using JSON format to help performance?
              I have onchange event on the dropdown box, it does not trigger onchange event when I have jQuery auto complete.  Is it normal that auto complete and onchange event has conflct?
              Thanks again for helping,
              Regards,
              Iccsi,
