1 Reply Latest reply on Jan 10, 2008 1:34 PM by Peter Flynn (Adobe)
    flex builder 3 bin-debug insert cvs
    newron9
      Why i cannot bin-debug directory of flex builder 3 beta 3 insert cvs ?
        • 1. Re: flex builder 3 bin-debug insert cvs
          Peter Flynn (Adobe) Adobe Employee
          You're trying to check in your bin-debug directory into CVS source control?
          Since bin-debug is your output folder, it is marked in Eclipse as a "derived" resource. These resources are typically ignored by source control because they can be derived entirely from the source code that *is* under source control. Thus it would be redundant to place it under CVS, and it would add overhead since any code change will also change bin-debug's contents.
          So I would highly recommend leaving it out of CVS for this reason. But if you really have a need to manage it under source control, you should be able to do so using a CVS client outside of Eclipse (the command line, WinCvs, etc.).
          - Peter
