2 Replies Latest reply on Sep 19, 2013 2:28 PM by samanthmachavez
    CS6 Advanced Photo Album Template Upload Issue
    samanthmachavez
      When I send the .swf to my coworker the images do not load. I have already made sure they image files are in the same folder has the .swf file. Please help
      Here is my code:
      import fl.data.DataProvider;
      import fl.events.ListEvent;
      import fl.transitions.*;
      import fl.controls.*;
      // USER CONFIG SETTINGS =====
      var secondsDelay:Number = 2;
      var autoStart:Boolean = true;
      var transitionOn:Boolean = true; // true, false
      var transitionType:String = "Squeeze"; // Blinds, Fade, Fly, Iris, Photo, PixelDissolve, Rotate, Squeeze, Wipe, Zoom, Random
      var hardcodedXML:String = "<photos><image title='Quality Coverage'>image1.JPG</image><image title='Money Savings'>image2.JPG</image><image title='Home Insurance'>image3.JPG</image><image title='Fred Loya has Got You Covered'>image4.JPG</image></photos>";
      // END USER CONFIG SETTINGS
      // DECLARE VARIABLES AND OBJECTS =====
      var imageList:XML = new XML();
      var currentImageID:Number = 0;
      var imageDP:DataProvider = new DataProvider();
      var slideshowTimer:Timer = new Timer((secondsDelay*1005), 0);
      // END DECLARATIONS
      // CODE FOR HARDCODED XML =====
      imageList = XML(hardcodedXML);
      fl_parseImageXML(imageList);
      // END CODE FOR HARDCODED XML
      // EVENTS =====
      imageTiles.addEventListener(ListEvent.ITEM_CLICK, fl_tileClickHandler);
      function fl_tileClickHandler(evt:ListEvent):void
          imageHolder.imageLoader.source = evt.item.source;
          currentImageID = evt.item.imgID;
      playPauseToggle_mc.addEventListener(MouseEvent.CLICK, fl_togglePlayPause);
      function fl_togglePlayPause(evt:MouseEvent):void
          if(playPauseToggle_mc.currentLabel == "play")
              fl_startSlideShow();
              playPauseToggle_mc.gotoAndStop("pause");
          else if(playPauseToggle_mc.currentLabel == "pause")
              fl_pauseSlideShow();
              playPauseToggle_mc.gotoAndStop("play");
      next_btn.addEventListener(MouseEvent.CLICK, fl_nextButtonClick);
      prev_btn.addEventListener(MouseEvent.CLICK, fl_prevButtonClick);
      function fl_nextButtonClick(evt:MouseEvent):void
          fl_nextSlide();
      function fl_prevButtonClick(evt:MouseEvent):void
          fl_prevSlide();
      slideshowTimer.addEventListener(TimerEvent.TIMER, fl_slideShowNext);
      function fl_slideShowNext(evt:TimerEvent):void
          fl_nextSlide();
      // END EVENTS
      // FUNCTIONS AND LOGIC =====
      function fl_parseImageXML(imageXML:XML):void
          var imagesNodes:XMLList = imageXML.children();
          for(var i in imagesNodes)
              var imgURL:String = imagesNodes[i];
              var imgTitle:String = imagesNodes[i].attribute("title");
              imageDP.addItem({label:imgTitle, source:imgURL, imgID:i});
          imageTiles.dataProvider = imageDP;
          imageHolder.imageLoader.source = imageDP.getItemAt(currentImageID).source;
          title_txt.text = imageDP.getItemAt(currentImageID).label;
      function fl_startSlideShow():void
          slideshowTimer.start();
      function fl_pauseSlideShow():void
          slideshowTimer.stop();
      function fl_nextSlide():void
          currentImageID++;
          if(currentImageID >= imageDP.length)
              currentImageID = 0;
          if(transitionOn == true)
              fl_doTransition();
      function fl_prevSlide():void
          currentImageID--;
          if(currentImageID < 0)
              currentImageID = imageDP.length-1;
              fl_doTransition();
      function fl_doTransition():void
          if(transitionType == "Blinds")
              TransitionManager.start(imageHolder, {type:Blinds, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Fade")
              TransitionManager.start(imageHolder, {type:Fade, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Fly")
              TransitionManager.start(imageHolder, {type:Fly, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Iris")
              TransitionManager.start(imageHolder, {type:Iris, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Photo")
              TransitionManager.start(imageHolder, {type:Photo, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "PixelDissolve")
              TransitionManager.start(imageHolder, {type:PixelDissolve, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Rotate")
              TransitionManager.start(imageHolder, {type:Rotate, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Squeeze")
              TransitionManager.start(imageHolder, {type:Squeeze, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Wipe")
              TransitionManager.start(imageHolder, {type:Wipe, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Zoom")
              TransitionManager.start(imageHolder, {type:Zoom, direction:Transition.IN, duration:0.25});
          } else if (transitionType == "Random")
              var randomNumber:Number = Math.round(Math.random()*9) + 1;
              switch (randomNumber) {
                  case 1:
                      break;
                  case 2:
                      break;
                  case 3:
                      break;
                  case 4:
                      break;
                  case 5:
                      break;
                  case 6:
                      break;
                  case 7:
                      break;
                  case 8:
                      break;
                  case 9:
                      break;
                  case 10:
                      break;
          } else
              trace("error - transitionType not recognized");
      if(autoStart == true)
      // END FUNCTIONS AND LOGIC
      /* Click to Load/Unload SWF or Image from a URL.
      Clicking on the symbol instance loads and displays the specified SWF or image URL. Clicking on the symbol instance a second time unloads the SWF or image.
      Instructions:
      1. Replace "http://www.helpexamples.com/flash/images/image1.jpg" below with the desired URL address of the SWF or image. Keep the quotation marks ("").
      2. Files from internet domains separate from the domain where the calling SWF resides cannot be loaded without special configuration.
      imageHolder.addEventListener(MouseEvent.CLICK, fl_ClickToLoadUnloadSWF);
      import fl.display.ProLoader;
      var fl_ProLoader:ProLoader;
      //This variable keeps track of whether you want to load or unload the SWF
      var fl_ToLoad:Boolean = true;
      function fl_ClickToLoadUnloadSWF(event:MouseEvent):void
          if(fl_ToLoad)
              fl_ProLoader = new ProLoader();
              addChild(fl_ProLoader);
          else
              fl_ProLoader.unload();
              removeChild(fl_ProLoader);
              fl_ProLoader = null;
          // Toggle whether you want to load or unload the SWF
          fl_ToLoad = !fl_ToLoad;
      Instructions:
      imageHolder.addEventListener(MouseEvent.CLICK, fl_ClickToLoadUnloadSWF_2);
      var fl_ProLoader_2:ProLoader;
      var fl_ToLoad_2:Boolean = true;
      function fl_ClickToLoadUnloadSWF_2(event:MouseEvent):void
          if(fl_ToLoad_2)
              fl_ProLoader_2 = new ProLoader();
              fl_ProLoader_2.load(new URLRequest("http://www.helpexamples.com/flash/images/image1.jpg"));
              addChild(fl_ProLoader_2);
          else
              fl_ProLoader_2.unload();
              removeChild(fl_ProLoader_2);
              fl_ProLoader_2 = null;
          fl_ToLoad_2 = !fl_ToLoad_2;
