2 Replies Latest reply on Sep 20, 2013 8:07 PM by JJMack
    how do I move a jpeg over to my new document?
    d.oliver32
      How do I move a jpeg into a new file I made. I have a project for school and I can not remember how.
      I made a new file, and then I open the pictures I want but how do I select them as the size they are and put them in my new file?
        • 1. Re: how do I move a jpeg over to my new document?
          Noel Carboni Level 8
          Select - All (or Control A) followed by Edit - Copy (Control C) followed by switching to the other document and Edit - Paste (Control V) is one way.
          Or you can Duplicate Layer from within the Layers panel.
          Or you can drag a file from Explorer or Finder onto an open document and place it on top.
          Once the image is pasted or placed into the document as a new layer, it can be resampled to the size you need it.
          -Noel
          • 2. Re: how do I move a jpeg over to my new document?
            You can also us menu File>Place to place the image in as a smart object layer. If the Jpg image is larger then your document Place will transform the smart object layer to fit governed by Adobe's default Photoshop preference for resizing placed documents.
            Copy and past and duplicate layer to an other document may add a layer larger then canvas size. Photoshop will match the layer to target document's resolution to keep the image being pasted or duplicated size the same size as the original so you need to be concerned with both documents  dpi resolution. If the added layer is larger then canvas size the canvas size will act like a clipping mask.
