9 Replies Latest reply on Oct 1, 2013 4:20 PM by Xiaoyi Tong
    No products are showing in my extension manager
    Lukas_A Level 1
      Hi!
      I have just downloaded and installed the Extension Manager for CC. I have CC installed since maybe a month ago (Mac OSX). When launching the extension manager, no products are showing up to the left under (products). I have also updated the version to 7.1 but that did not help. This means that I cannot install the extension manager toolbar. It gives me the error that "This extension cannot be installed, it requires illustrator 17.0 or higer).
      All other applications in my CC suite works fine,
      Any ideas?
      Thank you!
      Lukas
        • 1. Re: No products are showing in my extension manager
          shuo_yang Level 2
          Could you delete ExMan.db located in /Library/Application Support/Adobe/Extension Manager CC/Configuration/DB and try it again ?
          • 2. Re: No products are showing in my extension manager
            Lukas_A Level 1
            Hi!
            I just did that and it did not work. Any other ideas?
            Thank you
            Lukas
            • 3. Re: No products are showing in my extension manager
              shuo_yang Level 2
              Are you sure you installed illustrator CC not CS6
              • 4. Re: No products are showing in my extension manager
                Lukas_A Level 1
                Yes.
                This is how my Creative Cloud application looks:
                Thank you for your help!
                • 5. Re: No products are showing in my extension manager
                  Yuanyuan Liu Level 1
                  I cann't find Extension Manager CC in your snapshot.  Please install it from creative cloud. If you install it, the snapshot should like this:1.PNG
                  • 6. Re: No products are showing in my extension manager
                    Lukas_A Level 1
                    Hi!
                    I have installed the extension manager from the creative cloud application (before i downloaded it from adobes website where you could download it for CC). But it does not work anyway. I uninstalled the previous version before installing the new one of course. I have also tried to remove the DB file and start the extension manager.
                    How does the extension manager know what products I have installed? It seems that it cannot recognize them.
                    Thank you!
                    • 7. Re: No products are showing in my extension manager
                      Carl Sun Level 4
                      Have you moved the location of installed products? If yes, Extension Manager can't find them.
                      If not, you can install Adobe ExtendScript Toolkit CC in Creative Cloud Application then launch it. Input "BridgeTalk.__diagnostics__;" (exclude double quotation marks) in the main window, then click "Debug->Run". You will get diagnostics information in Javascript Console window at the top right corner.
                      Please check whether all installed products are listed under "Targets" section, and they have correct paths and exename. You can paste these output information here. Extension Manager retrieves information of supported products through BridgeTalk.
                      • 8. Re: No products are showing in my extension manager
                        Lukas_A Level 1
                        Hi!
                        Thank you for your reply!
                        Here are the results from the Bridge-talk operation:
                        Result: BridgeTalk Diagnostics
                                  Info:
                                            Name = estoolkit-4.0
                                            Status = PUMPING
                                            Group = cs
                                            Path = /Applications/Adobe ExtendScript Toolkit CC/ExtendScript Toolkit.app
                                            Version = 2.0
                                            Build = ES 4.5.5
                                            Next serial number = 40
                                            Logging: = OFF
                                            Now = 13:27:50
                                                      Message Version = 2.05
                                                      Authentication = ON
                                                      Digest = ON
                                  Thread: estoolkit-4.0#thread
                                            Avg. pump interval = 65ms
                                            Last pump = 25ms ago
                                            Ping: 7
                                                      ECHO_REQUEST: ECHO_RESPONSE
        Timeout = undefined
        Handler = undefined
                                                      STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
                                                      MAIN: MAIN
        Timeout = undefined
        Handler = installed
                                                      LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
                                                      DIAGNOSTICS: DIAGNOSTICS
        Timeout = undefined
        Handler = installed
                                                      INFO: INFO
        Timeout = undefined
        Handler = installed
                                                      SETUPTIME: thread=1ms, left=22ms
        Timeout = undefined
        Handler = undefined
                                  Instances: 3
                                            estoolkit-4.0#dbg:
        msg[13:27:50]: 00000035
        @BT>Version = 2.05
        Target = estoolkit-4.0#dbg
        Sender = estoolkit-4.0#dbg
        Sender-ID = localhost:mac14247
        Timeout = 12:27:51
        Type = Ignore
        Response-Request = Timeout
        Headers = (no headers)
        Timestamp = 13:27:50
        Serial-Number = 35
        Received = undefined
        Result = undefined
        Error = undefined
        Body = (empty)
                                                      Incoming: 1
                                                      Outgoing: 0
                                                      Handler: 9
        ExtendScript = for all messages
        Error = for only msg #25
        Error = for only msg #27
        Error = for only msg #31
        Result = for only msg #35
        Error = for only msg #35
        Timeout = for only msg #35
        Result = for only msg #37
        Error = for only msg #37
                                            estoolkit-4.0#estk:
        msg[13:27:50]: 00000037
        @BT>Version = 2.05
        Target = estoolkit-4.0#estk
        Timeout = 13:37:50
        Type = Debug
        Response-Request = Result Error
        Serial-Number = 37
        Result = undefined
        Error = undefined
        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                                                      Incoming: 1
                                                      Outgoing: 0
                                                      Handler: 1
                                            estoolkit-4.0: (main)
                                                      Incoming: 0
                                                      Outgoing: 0
                                                      Handler: 1
                                  Targets: 4
                                            Connector = PCD
                                            Installed: 0
                                            Running: 0
                                                      bridge-6.064:
        Group = cs
        Path = /Applications/Adobe Bridge CC/Adobe Bridge CC.app
        Display Name = Bridge CC
        MsgAuthentication = ON
        MsgDigest = ON
        ESTK = ON
        BundleID = com.adobe.bridge6
        Status = (not running)
        ExeName = Adobe Bridge CC.app
                                                      estoolkit-4.0: PUMPING
        Group = cs
        Display Name = ExtendScript Toolkit CC
        MsgDigest = ON
        ESTK = ON
        Status = PUMPING
        Info:
        Group = cs
        Version = 2.0
        Build = ES 4.5.5
        Next serial number = 44
        Logging: = OFF
        Now = 13:27:50
        Authentication = ON
        Digest = ON
        Last pump = 228ms ago
        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: PUMPING
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = undefined
        ExeName = ExtendScript Toolkit.app
                                                      exman-7.0: IDLE
        Group = cs
        Path = /Applications/Adobe Extension Manager CC/Adobe Extension Manager CC.app
        Display Name = Adobe Extension Manager CC
        MsgDigest = ON
        ESTK = OFF
        BundleID = com.adobe.exman
        Status = IDLE
        Info:
        Group = cs
        Version = 2.0
        Build = ES 3.92.104
        Next serial number = 3
        Logging: = OFF
        Now = 13:27:53
        Authentication = ON
        Digest = ON
                                                      exman-7.0: IDLE
        Thread: exman-7.0#thread
        Avg. pump interval = 3727ms
        Last pump = 202ms ago
        Ping: 7
        Timeout = undefined
        Handler = undefined
        STATUS: IDLE
        Timeout = undefined
        Handler = undefined
        MAIN: MAIN
        Timeout = undefined
        Handler = installed
        LAUNCHED: LAUNCHED
        Timeout = undefined
        Handler = installed
        Timeout = undefined
        Handler = installed
        INFO: INFO
        Timeout = undefined
        Handler = installed
        SETUPTIME: thread=0ms, left=1171ms
        Timeout = undefined
        Handler = undefined
        ExeName = Adobe Extension Manager CC.app
                                                      switchboard-3.064:
        Group = cs
        Path = /Applications/Adobe Bridge CC/Adobe Bridge CC.app/Contents/MacOS/SwitchBoard.app
        Display Name = SwitchBoard 3.0
        MsgDigest = ON
        ESTK = OFF
        ExeName = SwitchBoard.app
                                            Installed: 2
                                            Running: 2
                                            Groups: 140
                                                      cs3:
        acrobat-8.0
        aftereffects-8.0
        soundbooth-1.0
        bridge-2.0
        contribute-4.5
        devicecentral-1.0
        dreamweaver-9.0
        encore-3.0
        estoolkit-2.0
        fireworks-9.0
        flash-9.0
        illustrator-13.0
        indesign-5.0
        indesignserver-5.0
        incopy-5.0
        photoshop-10.0
        premiere-3.0
        premierepro-3.0
        stockphotos-1.5
        audition-3.0
                                                      cs4:
        acrobat-9.0
        aftereffects-9.0
        soundbooth-2.0
        bridge-3.0
        contribute-5.0
        devicecentral-2.0
        dreamweaver-10.0
        encore-4.0
        estoolkit-3.0
        fireworks-10.0
        flash-10.0
        illustrator-14.0
        indesign-6.0
        indesignserver-6.0
        incopy-6.0
        photoshop-11.*
        premierepro-4.0
        audition-4.0
        ame-1.0
        exman-2.0
                                                      cs5:
        acrobat-9.0
        aftereffects-10.0
        soundbooth-3.0
        bridge-4.0
        contribute-6.0
        devicecentral-3.0
        dreamweaver-11.0
        encore-5.0
        estoolkit-3.5
        fireworks-11.0
        flash-11.0
        illustrator-15.0
        indesign-7.0
        indesignserver-7.0
        incopy-7.0
        photoshop-12.*
        premierepro-5.0
        audition-5.0
        ame-2.0
        exman-3.0
        flashbuilder-4.0
        flashcatalyst-1.0
                                                      ts1:
        captivate3-en_us
        captivate3-fr_fr
        captivate3-it_it
        captivate3-ja_jp
        captivate3-es_es
        captivate3-de_de
                                                      ts2:
        captivate-4.0
                                                      el2:
        captivate-5.0
                                                      as1:
        acrobat-10.0
                                                      ts3:
        robohelp-9.0
        framemaker-10.0
                                                      cs55:
        aftereffects-10.5
        audition-4.0
        bridge-4.1
        contribute-6.1
        devicecentral-3.5
        dreamweaver-11.5
        encore-5.1
        estoolkit-3.6
        fireworks-11.1
        flash-11.5
        illustrator-15.1
        indesign-7.5
        indesignserver-7.5
        incopy-7.5
        photoshop-55.*
        premierepro-5.5
        ame-2.5
        exman-5.5
        flashbuilder-4.5
        flashcatalyst-1.5
        switchboard-2.0
                                                      el25:
        captivate-5.5
                                                      cs60:
        aftereffects-11.0
        audition-5.0
        bridge-5.*
        contribute-6.88
        devicecentral-4.0
        dreamweaver-12.0
        encore-6.0
        estoolkit-3.8
        fireworks-12.0
        flash-12.0
        illustrator-16.*
        indesign-8.0
        indesignserver-8.0
        incopy-8.0
        photoshop-60.*
        premierepro-6.0
        ame-6.0
        exman-6.0
        flashbuilder-4.52
        switchboard-2.0
        prelude-1.0
        speedgrade-6.0
                                                      el60:
        captivate-60.*
                                                      ts4:
        robohelp-10.0
        framemaker-11.0
                                                      cs70:
        audition-6.0
        bridge-6.*
        dreamweaver-13.0
        encore-7.0
        fireworks-13.0
        flash-13.0
        illustrator-17.*
        indesign-9.*
        indesignserver-9.0
        incopy-9.*
        photoshop-70.*
        premierepro-7.0
        ame-7.0
        exman-7.0
        flashbuilder-5.0
        prelude-2.0
        estoolkit-4.0
        aftereffects-12.0
                                                      el70:
        captivate-70.*
                                                      cs70:
        switchboard-3.*
                        I hope this was helpful for you to understand where the problem is.
                        As you can see the other applications do not have a "Path" variable. I have not moved my applications. Thank you!
                        • 9. Re: No products are showing in my extension manager
                          Xiaoyi Tong Adobe Employee
                          Hi Lukas_A,
                          Based on your log above, we know you have ESTK, Bridge CC and Extension Manager CC installed, but we did not find illustrator CC. It may be caused by the updating database error in illustrator's installation. You can check if /Applications/Adobe Illustrator CC\Adobe Illustrator CC.app exists and can be launched successfully. If it works, you can try to remove it, reboot your system, and install illustrator CC again by Creative Cloud Application.
                          Xiaoyi
