4 Replies Latest reply on Sep 24, 2013 1:04 AM by Sathya Rani M
    Reg. Bold Formatting apply to the text
    Sathya Rani M
      Hi All,
      Can anybody help me out to sort this issue. I need to apply the bold formatting to the specific text of the textframe contents.
      Here is the scenario.
          var seq = 0;
          var doc = app.activeDocument;
          np = doc.pages.add();
          marg = np.marginPreferences;
          gb = [marg.top, marg.left,
          doc.documentPreferences.pageHeight - marg.bottom,
          doc.documentPreferences.pageWidth - marg.right];
          oldRuler = doc.viewPreferences.rulerOrigin
          doc.viewPreferences.rulerOrigin = RulerOrigin.pageOrigin;
          var aqFrame = doc.pages[-1].textFrames.add();
          aqFrame.geometricBounds = gb;
          previousTextFrame = doc.pages[-2].textFrames[0];
          for (var aq in aqCont) // aqCont Array have contents
              seq = (aq*1)+1;
              aqFrame.contents += "Q"+seq+"\t"+"Au:"+"\t"+aqCont[aq]+"\n";
          doc.viewPreferences.rulerOrigin = oldRuler
      In this i need "Q"+seq i.e Q1, Q2, Q3.... alone should be bold.
      Needed output:
      Q1     Au:     text1
      Q2     Au:     text2
      Any help is greatly appreciated. Thanks in advance.
      ~Sathya Rani M
        • 1. Re: Reg. Bold Formatting apply to the text
          Jump_Over Level 5
          I suggest to apply "bold" to each "Q\d+" occurrence in this textFrame's contents.
          It could be in paragraph style's definition (nested Grep) or made by Find...Change (by script or manually).
          Jarek
          • 2. Re: Reg. Bold Formatting apply to the text
            Sathya Rani M Level 1
            Thank you for the reply and this could be fine to apply paragraph style to every occurance of "Q\d+" by grep.
            By doing this way, the tool can execute at each line of document but in my case these occurances are exist only in the last page. So I have searched a way to apply bold while adding contents itself, also this will be helpful in fasting our execusion.
            I think there is no way other than you suggested! -- Thank you.
            ~Sathya Rani M
            • 3. Re: Reg. Bold Formatting apply to the text
              Jump_Over Level 5
              If there is not a separate paraStyle for those content you can make it straight forward
              (charStyle "Bold" is defined):
              sBold = doc.characterStyles.item("Bold");
              aqFrame.paragraphs.everyItem().nestedGrepStyles.add({
                   appliedCharacterStyle: sBold,
                   grepExpression: "^Q\\d+"
              executing after content is placed
              Jarek
              • 4. Re: Reg. Bold Formatting apply to the text
                Great! It is working fine for me now. Thank you.
                I have changed the characterStyle as below.
                    var sBold = doc.characterStyles.item("B"); // Instead of Bold
                Once again thank you for assisting me in a right way...
                ~Sathya Rani M
