2 Replies Latest reply on Sep 23, 2013 3:53 PM by Nancy OShea
    Common Menu Tab in DW CS6
    jhatley
      On the common menu tab I have duplicate icons of the same extenion, how can I delete the duplicate?
        • 1. Re: Common Menu Tab in DW CS6
          mytaxsite.co.uk Level 6
          What is common Menu Tab?  I don't have in CS6.
          However, to manage your extensions and to remove any you don't need then the process is as follows:
          Help >> Manage Extensions
          See this picture:
          There is button next to the extension that allows you to remove it.
          Good luck and post back if you know what is Common Menu Tab.  i like to keep a note of different terminology used in these forums.
          • 2. Re: Common Menu Tab in DW CS6
            In DW CS6, the Common tab is located inside the Insert Panel.
            Nancy O.
