2 Replies Latest reply on Sep 23, 2013 1:50 PM by ojodegato
    adding/substracting from selection
    ojodegato Level 1
      When adding/substracting from an exhisting selection I often use the wrong option in the selection module in the tool bar. I understand the theory behind the selection process in principal. However, I ofte end up doing the oposite. Has anyone found a technique to add/substract from an exhisting selection that is more effective than using the istructions suggeted by the software help menu.
        • 1. Re: adding/substracting from selection
          MikeGondek Adobe Community Professional & MVP
          Use any of the selection tools and hold down the modifier key to add
          Shift - add
          Option/Alt - subtract
          Same modifier keys work with masks, or tthe tranparency on a layer. There is also Intersection which is helpful, to select the common transparency between 2 items.
          Shift & Option - Intersection
          • 2. Re: adding/substracting from selection
            ojodegato Level 1
            The confusing part when using the modifier keys is that  it is not very clear which side of the selection is affected.
            Is it possible to apply a temporary visual mask to the selection while modifying the selection with the lasso tool. Similar to using the quick  mask and brush tool  combination.
