1 Reply Latest reply on Sep 24, 2013 5:03 PM by elainecc
    Stroked paths / masks
    KoMaruyama Adobe Community Professional
      Is it possible to stroke a path or mask shape in EdgeAnimate?
      I'd like to animate a rope moving, but it only requires a single color.  Do I need to create a sprite sheet for this? or can I create a path, and stroke it with color?
      alt: I may look into using SVG sequenced elements from Illustrator. can svg files be used like a sprite page?
        • 1. Re: Stroked paths / masks
          elainecc Adobe Employee
          Hi, Ko-
          Non-canvas HTML is limited to rectangular masks, unfortunately.  You can do sprite sheets using SVGs and clipping, but you should definitely check to see what the file size is and optimize as much as you can.  Also, SVGs are not always served properly by webservers, so you should make sure that your server is configured to serve SVGs as image files.
          Hope this helps to point you in the right direction, and welcome to the Animate forum!
          -Elaine
