1 Reply Latest reply on Sep 24, 2013 1:56 AM by sjpt
    ADE doesn't connect to Sony ereader anymore
    Koshgirl
      My sony eReader was coming up in ADE but now is not recognised.  The computer is authorized and purchased books can be opened in ADE but cannot be opened when transfered to the ereader by Sony Reader software or drop and drag.  I've factory reset reader and uninstalled and reinstalled all software.  Can anyone help
        • 1. Re: ADE doesn't connect to Sony ereader anymore
          sjpt Level 4
          Looks like two separate problems.
          1 - The eReader is no longer authorized to your Adobe ID, probably as a result of the factory reset.
          You should be able to authorize from the Sony Reader for PC program;
          or if you get issue 2 solved, from ADE.
          2 - Sony device not recognized by ADE
          You need to have a running device driver for the Sony to be recognized by ADE.
          (not sure why, no other eReaders have this inconvenience)
          Usually, this driver is available as long as you have installed the Sony Reader program,
          whether or not you run the Sony Reader program itself.
          It seems you have done what you should for this all to work, but ... maybe something went wrong there?
          There are bugs in ADE2.0 with the Sony devices; especially if you use Overdrive library books.
          I have found v1.7.2 much more reliable in various ways, it may be worth trying that.
          If that works, you should then be able to reauthorize the eReader.
          There are lots of bugs in ADE2.0.  Try replacing ADE2.0 with the older but more reliable v1.7.2.
          (You can have them both installed at once if you like.)
          Version 1.7.2, it is a little difficult to find, available on Adobe site for Windows and for Mac.
          http://helpx.adobe.com/digital-editions/kb/cant-install-digital-editions.html
          The forum software is sometimes corrupting the link above.  There shouldn't be a blank in 'editio ns.html'.  The following redirects to the same page: http://tinyurl.com/diged172
