Word keeps trying top open PDFs. How do I stop it?
Specifics depend on platform and OS version, but this can help.
Right click on the icon of a known PDF and go to Porperties/Get Info. If the Open With sections doesn't show Reader, change it. Make sure that the change affects all files of the same type.
It still doing it. This seems to have happened after I received some docs
from a mac. My word documents also keep wanting to save in a docx format.
does this make sense?
I'm using windows 7
Judy Faulkner
Chartered psychologist
Chartered scientist
HCPC registered
07971581657
Nothing unusual about wanting to save in DOCX format, that's the default for Word (but you can change it to DOC, if someone in Word 2003 or earlier needs to read it).
Try going to the Programs control panel
- select Adobe Reader
- click Change
- DO NOT select uninstall
- Click Repair
Just tried that. Adobe still cant open pdfs
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
You need to change the file association for .pdf files to open with Adobe Reader; see http://windows.microsoft.com/is-is/windows7/change-the-program-that-opens-a-type-of-file
Nope I cant see where it gives me the choice to change the software- I know
it's probably me . Any more specific help?
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
Well, let's take a different approach as fixing double clicking seems to be getting nowhere fast.
Can you start Adobe Reader from the Start button?
Can you use File > Open (in Adobe Reader) to open the PDF files you need?
Yes I can open adobe but it then says something like 'adobe can't open
this file ....
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
What does it say EXACTLY?
Adobe reader could not open 'ssmple literature review. Docx because it is
either not a supported file type or because the file has been damaged (for
example, it was sent as an email attachment and wasn't correctly decoded).
Well, actually, everything has been working fine because a DOCX file isn't a PDF. It's a Word document. What has led you to assume it's a PDF?
It has the pdf symbol on it. Also, other pdfs that I know are pdfs wont
open.
Also, adobe trys to open them. Why?
I don't know why Adobe Reader tries to open them. We weren't making much headway there, so I'm trying to make sure you can at least open your PDF files.
The PDF symbol is basically the same thing as the program used to open the file: it's one problem not two.
Let's look at your point "Also, other pdfs that I know are pdfs wont open.". Can you give the error message from something that really is a PDF file?
It opens with the box that has symbols on the right and a selction on the
left including ms dos. Im on a train at the moment so csn look ptoperly
later
Thanks for your help
I can't make anything of that description. We may need a screen shot. Do you know how to make one?
Did you get the print screen?
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
I'm afraid not. Did you try to attach it to an email? That doesn't work. You need to save it as a JPEG, then come to the forum (view full discussion link). As you type your reply, click the Camera icon.
From all your posts I gather that
You must change these file associations to open with the correct program (.docx → Word; .pdf → Reader). Use the instructions in the link I posted earlier.
Yes that's right. I have attached the printscreen now
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
Did you try to attach a print screen TO AN EMAIL REPLY again? Won't work as I already said.
I saved it to word and then attached it. but I noticed it had the adobe
symbol on it
Judy Faulkner
Chartered scientist
HCPC registered
07971581657
The ONLY WAY to add a screen shot is to follow the instructions I sent before. Word is not involved. Email is not involved.
The instructions were: You need to save it as a JPEG, then come to the forum (view full discussion link). As you type your reply, click the Camera icon.
Let us know if there is a difficulty following these instructions.
