2 Replies Latest reply on Sep 24, 2013 11:29 PM by DavideBenzoni
    how create a mixedcolor in javascritp
    DavideBenzoni
      Below a segment of my scritp but there is an error in the assignment of colors
      try{
      myDocument.colors.item("doublecolor").name;
      catch (myError){
         myDocument.mixedInks.add({name:"sbalzooro", model:ColorModel.MIXEDINKMODEL, space:ColorSpace.MIXEDINK,inkList:["Process Cyan","Process Magenta","sbalzo", "PANTONE 871 C"],inkPercentages:[0,0,100,100]});
      thanks
        • 1. Re: how create a mixedcolor in javascritp
          Marc Autret Level 4
          Hi Davide,
          MixedInks.add(…) expects the following arguments, in that order:
          inkList (array of Inks or MixedInkGroup)
          inkPercentages (Array of numbers)
          withProperties (Object w/ additional mixed ink props — optionnal)
          Note that inkList, if supplied as an array, must contains actual existing (=valid) Ink specifiers (rather than ink names). So I suggest you implement a ink validator routine.
          Here is a possible approach:
          // Your settings
          var MY_MIX_INKS = {
              // Valid ink names are required -- At least 2 process inks are required
              'Process Cyan'    :   0,      // Process1 : %
              'Process Magenta' :   0,      // Process2 : %
              'sbalzo'          : 100,      // Custom1  : %
              'PANTONE 871 C'   : 100       // Custom2  : %
              MY_MIX_NAME = 'doublecolor';
          // Ink Validator
          var validateInkData = function(/*{name: %}*/o, /*inks*/c, /*&inklist*/ll, /*&inkPerc*/pp)
              var k, t, z=0, r=1;
              ll.length = pp.length = 0;
              for( k in o )
                  if( !o.hasOwnProperty(k) ) continue;
                  if( !(t=c.itemByName(k)).isValid ){ r=0; break; }
                  ll[z] = t.getElements()[0];
                  pp[z++] = +o[k];
              return r;
          // Main process
          var doc = app.activeDocument,
              inkList,    // will receive validated ink list (array)
              inkPerc;    // corresponding percentages (array)
          if( !doc.mixedInks.itemByName(MY_MIX_NAME).isValid )
              if( validateInkData(MY_MIX_INKS, doc.inks, inkList=[], inkPerc=[]) )
                  doc.mixedInks.add(inkList, inkPerc,
                      model: ColorModel.MIXEDINKMODEL,
                      space: ColorSpace.MIXEDINK
                  alert( "The mixed ink '" + MY_MIX_NAME + "' has been successfully created." );
              else
                  alert( "Unable to create mixed ink. Some inner inks are missing." );
          else
              alert( "The mixed ink '" + MY_MIX_NAME + "' already exists." );
          Marc
          • 2. Re: how create a mixedcolor in javascritp
            DavideBenzoni Level 1
            Thanks Marc,
            now everything is OK.
            I need to understand the steps. I am just a beginner.
