1 Reply Latest reply on Sep 24, 2013 9:59 AM by Umami Design
    I recently downloaded CS-6.  How do I keep several pages open so as to drag items between them?
    Bobsb
      I am used to working with Photoshop CS.  I recently sownloaded CS-6.  What do I have to do to keep several pages open at the same ttime so as to drag layered items between them?
        • 1. Re: I recently downloaded CS-6.  How do I keep several pages open so as to drag items between them?
          Umami Design
          Visit the menu "Window / Arrange / ..." where you'll find a "Float in Windows..." option. If you happened to have several images open simply select "Float All in Windows." From here you can drag between windows. However, to make things easier (depending on how many images are open) I've found the following useful.
          1. Select "Float All in Window" from the "Window / Arrange / ..." menu
          2. Select "Tile" from the same menu.
          3. Select a single images and zoom-out until the images is comparable to a thumbnail.
          3. Select "Match All" from the same "Window / Arrange / ..." menu
          4. Select an images or layer, hold down CMD + SHIFT, and drag it to the desired canvas.
               Note: Holding down "Shift" ensures it aligns center on the destination canvas. Or dragging onto the workspace, as opposed to the actual canvas, can do the same.
          ...hope that helps.
