2 Replies Latest reply on Sep 25, 2013 4:53 AM by Green4ever
    run in all open docs
    nellbern Level 1
      I'm trying to run this script  in all open  ID docs but it's only changing only 1 document instead of all . I know is something simple but I can't figure it out. Please advise where am I making the mistake.
      tell application "Adobe InDesign CS4"
      activate
                repeat with i from 1 to count of documents
                          set myFiles to active document
                          tell myFiles
                                    try
                                              try
                                                        set theListOfColors to (every swatch whose model is spot and name begins with "P 555")
                                                        set properties of item 1 of theListOfColors to {model:process, space:CMYK, color value:{0, 0, 0, 100}}
                                              end try
                                              try
                                                        set ListOfColors to (every swatch whose model is process and name begins with "P 555")
                                                        set properties of item 1 of ListOfColors to {model:process, space:CMYK, color value:{0, 0, 0, 100}}
                                              end try
                                              try
                                                        set (model of every color whose model is spot) to process
                                              end try
                                    on error the error_message number the error_number
                                              set the error_text to "Error: " & the error_number & ". " & the error_message
        display dialog the error_text buttons {"OK"} default button 1
                                              return the error_text
                                    end try
                          end tell
                end repeat
      end tell
        • 1. Re: run in all open docs
          Dave Saunders Level 4
          I'm no AppleScripter, but it seems to me that if you go to the trouble of setting up a variable I to walk through the documents you should use it.
          I'd say it's bad form to use "myFiles" as the name for a variable that holds a reference to a single document.
          Someone might need to backstop my code, but you should be able to use:
          repeat with myDoc in documents
          tell myDoc
          Dave
          • 2. Re: run in all open docs
            Green4ever Level 3
            Nellbern,
            In the statement "set myFiles to activeDocument", myFiles holds only one document eventhough the loop is running properly. Please try as Dave said else change your code to loop throught the each documents properly.
            ~Green4ever
