1 Reply Latest reply on Sep 25, 2013 7:39 AM by Gyan1010
    app.openDoc only working for .pdf not anything needing conversion
    Gyan1010
      So I've been trying to add to a script i wrote in AutoIt that gives it the ability to convert a .html file to a .pdf
      AutoIt uses similar object creation to VBScript, and I've been able to access the JSObject with
      $oApp = ObjCreate("AcroExch.App")
      $oApp.Show
      $oAVDoc = ObjCreate("AcroExch.AVDoc")
      $oAVDoc.Open("C:\test.pdf","C:\test.pdf")
      $oPDDoc = $oAVDoc.GetPDDoc
      $oJSO = $oPDDoc.GetJSObject
      $oJSO.console.show
      $oJSO.console.clear
      Then from here, I can open a different pdf just fine with something like
      $oJSO.app.openDoc("C:\test1.pdf")
      But when i try
      $oJSO.app.openDoc("C:\test.htm")
      it fails and the console shows
      NotAllowedError: Security settings prevent access to this property or method.
      App.openDoc:0:
      I tried using this next
      $oJSO.app.beginPriv()
      $oJSO.app.endPriv()
      but i got the same result.
      I want to try and use the bUseConv parameter but I'm not sure how to since in autoit I don't think you can do something like
      $oJSO.app.openDoc({cPath: "C:\test.htm", bUseConv: true})
      you need to use all the parameters before that and I'm not sure what to use for oDoc and the things I have tried all fail.
      $oJSO.app.openDoc("C:\test.htm", ???, "", false, true)
      I hope someone can help, thanks!
