• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Images show as grey box when imported into InDesign Trial Version
Community Beginner ,
Sep 25, 2013 Sep 25, 2013
I just got the trial versions of Photoshop and Indesign.  When I try to place an image into my InDesign document it shows up as a grey box, with an "X" across it, and a lock link in the upper left of said box.  How do I get the image to show?
TOPICS
How to , Import and export
Views
40.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Go to View > Display Performance and choose something other than Fast Display
Votes
Translate
Translate
Report
Report
Hi John,
I tried it and I still get the grey box.  It looks like for some reason it keeps converting the image to a frame.
Votes
Translate
Translate
Report
Report
Guru ,
How exactly are you trying to place the images?
Votes
Translate
Translate
Report
Report
File, place
Votes
Translate
Translate
Report
Report
Community Expert ,
Perhaps there is a persistent Display Performance > Fast Display setting assigned to the image itself. Select the image frame, then right-click and again choose Display Performance > something other than Fast Display...or..choose Use View Setting.
Votes
Translate
Translate
Report
Report
This worked...thank you soooo much!!
Votes
Translate
Translate
Report
Report
New Here ,
Apr 02, 2016 Apr 02, 2016
Thanks so so much !
Votes
Translate
Translate
Report
Report
Community Expert ,
Does this happen with all images, or just a particular one? It could be a problem with the image itself; it may need to be opened and resaved (maybe even under a new name) to fix it.
Votes
Translate
Translate
Report
Report
All images I have tried so far.
Votes
Translate
Translate
Report
Report
Guru ,
With no document open, go to Preferences > File handling and make sure the Raster settings are correct.
You want the slider for Raster Images to be set for Proxy
NOT Gray Out
Do the same with the document that's giving you problems open.
Votes
Translate
Translate
Report
Report
Hi Sandee...Thanks I got the answer that worked from John.
Votes
Translate
Translate
Report
Report
New Here ,
Jul 13, 2016 Jul 13, 2016
LATEST
Hello,
You probably press Ctrl+Alt+Shift+Z.
Go to View > Display Performance and choose "Typical Display"
Votes
Translate
Translate
Report
Report
