0 Replies Latest reply on Sep 25, 2013 9:10 AM by D@yzW0rk
    Cookie has a value when it should not
      I've been working on a bit of bot mitigation and began using checks against Cookie.CFID to verify the client has a value in reply.
      I'm using CF  9,0,1,274733
      application.cfm includes the following:
      <cfapplication sessionManagement="True" clientManagement ="False" setClientCookies="True" sessionTimeout="#CreateTimeSpan(0, 0, 2, 0)#">
      I disable cookies in FF 23 browser to simulate a bot and conduct the test.
      In my test the check for Cookie.CFID is as expected, empty.  Here is a snippet of code used to test this.
          <cfif REFind("YourIPAddress",CGI.REMOTE_ADDR)>
              <cfif ! IsDefined("Cookie.cfid")>
                      No Cookies as expected!
              <cfdump var="#Cookie#">
          <cfcatch type="Any">
              <cfdump var="#cfcatch#">
      And the result expected from that test:
      struct [empty]
      However, with the same test environment configuration as above in another page I'm getting a non empty struct when dumping cookies like this:
      Is there some function or feature in ColdFusion known to cause this behavior or is this a bug?
