0 Replies Latest reply on Sep 25, 2013 2:50 PM by Talex904
    What script would I use for a timesheet using 12:00 am?
    Talex904 Level 1
      I have been able to add a document level script using Acrobat Pro to show midnight as 12:00 am. But my calculations still don't work. As I have it scripted right now a start time of 12:00 am and an end time of 1:00 am equals -11.00 hours not 1.00 hour. What script would I have to add so the calculation is correct?
      Here is the script I have right now:
      // start time
      // Start time field name
      var cStartName = "start1mon1";
      // Start time format:
      var cStartFormat = "HH:MM";
      // end time
      // end time field name
      var cEndName = "end1mon1";
      // End time format:
      var cEndFormat = "HH:MM";
      // some conversion functions
      // function to convert time string to minutes
      function Time2Num(cTime, cFormat) {
      // convert time string to minutes
      // convert time string to date object
      var oDate = util.scand("mm/dd/yyyy " + cFormat, "01/01/1970 " + cTime);
      // convert date object to number of milliseconds
      var nTime = oDate.getTime();
      // convert milliseconds to minutes and return value
      return Math.round(nTime / (1000 * 60));
      } // end Time2Num function
      function Num2Time(nMinutes) {
      // convert time string to Hours and Minute
      // hours in nMinues
      var nHrs = Math.floor(nMinutes / 60);
      // remainder minutes from hours in nMinutes
      var nMins = nMinutes / 60;
      // return formatted time string
      return nHrs, nMins;
      } // end Num2Time
      // end conversion functions
      // perform the calculation using the fields:
      // get the values of the fields
      var cStartTime = this.getField(cStartName).value;
      var cEndTime = this.getField(cEndName).value;
      // clear the value
      event.value = "";
      // test for not null time strings
      if(cStartTime != "" && cEndTime != "") {
      // compute the time difference in minutes
      nDiff = Time2Num(cEndTime, cEndFormat) - Time2Num(cStartTime, cStartFormat);
      event.value = Num2Time(nDiff);
      } //end not null values
      I have no prior knowledge of JavaScript, only what I have found here on the forums and a lot of luck. I would appreciate help on this problem. Thanks!
