3 Replies Latest reply on Sep 29, 2013 7:45 AM by joe bloe premiere
    Weird color artifacts after 3 way color correction
    nettarb
      A student of mine is doing a color correction exercise and imported  quicktime .mov files to color correct.  Once she applied the 3 way color corrector very strange color artifacts showed up in some of her clips -- one looks like a green screen with the corner torn away edged in the lower right hand corner with festive diamond shaped green and magenta diamond shapes and only a tiny corner of the video is left that looks 'normal' in the lower right hand corner.
      Any ideas as to what is causing this?
        • 1. Re: Weird color artifacts after 3 way color correction
          joe bloe premiere Level 5
          First, what version of Premiere?
          System details are important.
          In particular, the display card make / model and driver version.
          Also, details regarding the quicktime file (codec, origin etc.) can help.
          Is the problem only associated with the one quicktime file, or
          does this problem occur using other media (including color bars
          generated from within Premiere)?
          A screenshot of the artifacts can be helpful.
          • 2. Re: Weird color artifacts after 3 way color correction
            nettarb Level 1
            Screen Shot 2013-09-27 at 3.05.30 PM.pngHi Joe Bloe.... Below is info you requested plus a screen shot.
            Version is CS6.
            ATI Radeon HD 4850:
              Chipset Model: ATI Radeon HD 4850
              Type: GPU
              Bus: PCIe
              PCIe Lane Width: x16
              VRAM (Total): 512 MB
              Vendor: ATI (0x1002)
              Device ID: 0x944a
              Revision ID: 0x0000
              ROM Revision: 113-B9110C-425
              EFI Driver Version:  01.00.383
              Displays:
            iMac:
              Display Type: LCD
              Resolution: 2560 x 1440
              Pixel Depth: 32-Bit Color (ARGB8888)
              Main Display: Yes
              Mirror: Off
              Online: Yes
              Built-In: Yes
              Connection Type: DisplayPort
            Any thoughts?
            Thanks.....Clare (Nettarb)
            • 3. Re: Weird color artifacts after 3 way color correction
