1 Reply Latest reply on Sep 26, 2013 3:17 AM by Craberoid
    Flex4 mxml data binding "public" issue
    屏幕aaaa
      I'm using flex builder4, then i wrote a mxml sample, but it can't compile successfully.
      MXML:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml">
      <mx:Script source="test.as"/>
      <mx:ControlBar id="ctlbar" horizontalAlign="right" width="100%"
      paddingRight="{maxFontSize}" paddingTop="0" paddingBottom="0">
      <mx:Button id="cancelBtn" label="Cancel" minWidth="11"/>
      </mx:ControlBar>
      </mx:Application>
      test.as:
      [Bindable]
      public var maxFontSize:Number = 115;
      I want to use "maxFontSize" as data binding, but it can't compile properly if i use flex sdk4.10, but if i use flex sdk3.5, it will compile successfully. Also if i change "public" to "internal", it will compile successfully even though use sdk4.10. But why this happened? Who knows that? Thanks.
        • 1. Re: Flex4 mxml data binding "public" issue
          Craberoid
          Hello.
          Adobe recommends to use spark components instead of mx in flex 4.x.
          So you can write like this:
                                           xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                    <fx:Script source="test.as" />
                    </mx:ControlBar>
          </s:Application>
          Or you can change namespaces and rewrite code like this (if you want to use mx:Application):
          <mx:Application  xmlns:fx="http://ns.adobe.com/mxml/2009"
                                                   xmlns:mx="library://ns.adobe.com/flex/mx">
                    <fx:Script source="test.as"/>
                    </mx:ControlBar>
          </mx:Application>
