2 Replies Latest reply on Sep 30, 2013 10:42 AM by AndrewMathieu
    Object Export Options...
    AndrewMathieu
      Would anyone know an easy way to access Object Export Options found in the Object menu of InDesign using a script?
      More specifically, we currently have a script with a dialogue that adds alt text to images in a document and has other features that are almost identical to the InDesign Object Export Options feature, but with slight differences.  We are trying to synchronize so that when a user adds an alt text thru our dialogue using our script, that the alt text will be changed automaticly specifically under Custom heading in the Object Export Options.
      I have found a similar example, at http://forums.adobe.com/message/5688491, but not quite what I'm looking for.
      Any ideas?
        • 1. Re: Object Export Options...
          AnshulJain19 Adobe Employee
          Hi Andrew,
          Do you need a script that will apply Alt Text as Custom type in Object Export Options for images in a document. Please find below script which does same thing:
          myGraphics = app.activeDocument.allGraphics;
          myTotalGraphics = myGraphics.length;
          for(var i=0; i<myTotalGraphics; i++)
                myGraphics[i].parent.objectExportOptions.altTextSourceType = SourceType.SOURCE_CUSTOM;
                myGraphics[i].parent.objectExportOptions.customAltText = "Graphic Number : " + i;
          -Anshul
          • 2. Re: Object Export Options...
            AndrewMathieu Level 1
            Thanks for the help Anshul.  Yes this worked.  Slight modifications to this code, but I was able to achieved the desired behaviour.
            Andrew
