5 Replies Latest reply on Sep 26, 2013 4:27 PM by the_wine_snob
    Horizontal to vertical orientation
    173abn
      Parts of a clip I want to use move from vertical to horizontal orientation, because I moved the camera (iPhone) when shooting. Unfortunately, the orientation of the clip changed as well. Can the horizontal parts be rotated to a vertical orientation? If yes, how? Thanks
        • 1. Re: Horizontal to vertical orientation
          A.T. Romano Level 7
          173abn
          Best you include what version of Premiere Elements that you are working with and the computer operating system on which it is operating.
          If versions 11 or 12, Applied Effects/Applied Effects Palette/Motion Panel expanded...in the Motion Panel is an option for Rotation. You can right click the video on the Expert workspace Timeline and select Rotate 90 degrees right or left.
          If version earlier than 11, Properties Palette/Motion Panel expanded...in the Motion Panel is the option for Rotation. Same about right clicking the video on the Timeline, selecting Rotate 90 degrees left or right.
          Please let us know if that targeted your question.
          Thank you.
          ATR
          • 2. Re: Horizontal to vertical orientation
            the_wine_snob Level 9
            Welcome to the forum.
            Also remember that when you do Rotate that portrait oriented footage, it will be used in the video frame, which will be horizontal, or landscape.
            You will have black bars on the side. You might want to leave those, for that Clip, or use the Fixed Effect>Motion>Scale (see ATR's directions for where to find the controls), to fill the width, effectively "cropping" top and bottom, until the width has been filled. You can then use Motion>Position, to move that effective cropping up, or down, as needed.
            • 3. Re: Horizontal to vertical orientation
              173abn Level 1
              Bill,
              It worked - now the full clip is oriented correctly, and I can use the footage as I intended.
              Thank you very much.
              Jim
              • 4. Re: Horizontal to vertical orientation
                A.T. Romano Level 7
                Jim
                Glad that the suggestion worked for you.
                Continued success.
                ATR
                • 5. Re: Horizontal to vertical orientation
                  173abn,
                  Excellent news. ATR gave you perfect instructions, and you followed those perfectly.
                  The orientation of footage, shot with a camera phone, CAN be a bit daunting, at first, but there are fixes, though they come with the caveat that I mentioned.
                  Since things are editing well now, I would urge you to list ATR's Reply as Correct, as that will let others know that you got the answers needed, so that they will read your post, to solve their problems, as well.
                  Adobe's Forum Team also monitors Correct and Helpful answers, to convince upper-management of the worth of the Adobe Forums.
                  Good luck, and happy editing,
