1. Re: Skipped Buttons Despite Order
Stan Jones Sep 26, 2013 4:01 PM (in response to Xoxidine)Click the button routing button in the menu viewer. Then change those as needed.
3. Re: Skipped Buttons Despite Order
Stan Jones Sep 26, 2013 4:10 PM (in response to Xoxidine)You have automatic routing turned on. (See the properties on the right.) The routing you turned off is actually the preference for how it works. Automatic routing is on by default.
For a menu that is layed out in lines, it can work pretty well. Since you have one column, and a bottom line, I'd turn off.
The number of a button is the number in the middle. And the numbers in the arrows is the button number it will go to if you click that direction. So right now, for your button 5, if you arrow down, you go to 7. Turn off automatic routing, then drag that 7 arrow to the 6 button, and it will change to a 6, And when you then arrow down, it will go to 6.
4. Re: Skipped Buttons Despite Order
Xoxidine Sep 26, 2013 4:12 PM (in response to Xoxidine)I found a YouTube video that explains it. In case anyone runs into my issue, here it is. https://www.youtube.com/watch?v=F-VK-Zf4n6k
5. Re: Skipped Buttons Despite Order
Xoxidine Sep 26, 2013 4:26 PM (in response to Xoxidine)Thank you Stan Jones, you've saved me all day today from this project that's trying desperatly to kill me.
