7 Replies Latest reply: Oct 17, 2013 12:15 AM by vari25 RSS
    How to link swf to database asp
    vari25 Community Member
      Hi All,
      I am in a fix,  I have a swf file to be linked to a database asp.
      Also I want my visible movieclips on stage to be listed in a output file.
      As I don't have any idea of how to do this, any help is appreciated.
      Thanks in advance.
        • 1. Re: How to link swf to database asp
          moccamaximum Community Member
          What kind of database?
          Is this required at runtime or at authoring time?
          • 2. Re: How to link swf to database asp
            As far as I know, Its a asp created server database i assume because i exactly don't know the what type of database it is.
            But i do know that, when the swf output file in a website is accessed the list of movieclips visible on stage (i.e., enabled through buttons) have to be created as a list,
            for the database to be further processed.
            So, the thing is wen the button (submit) for example is clicked, the movieclips which are enabled on stage to be added to a list.
            Any idea in this or help with this is appreciated.
            Thank you in advance.
            • 3. Re: How to link swf to database asp
              there are really dozens of scenarios for the usecase you describe.
              first thing: you somehow have to store the relevant Moviclips in an Objcet which can be an Array or a stribng or An XmlList whatever is easier for your webservice to process.
              Basics about connecting flash with asp here:
              http://blog.thinksharp.nl/2008/03/01/FlashCS3AndASPNETWebservicesInclSessions.aspx
              • 4. Re: How to link swf to database asp
                The link provided by you has a downlaodable library.
                But I have a file that is the images sequence file with color options with user interactive.
                That is the color changes when the user clicks on the button like garage_blue, garage_brown etc.
                Now when the user clicks the save button, the enabled movieclips or selected clors has to be generated in a list.
                Hope I made myself clear.
                Now, could you please suggest what could be done?
                Many thanks in advance.
                • 5. Re: How to link swf to database asp
                  there are at least 4 possibilities to handle this:
                  1.Store data in a LocalSharedObject
                  2.store data in simple texts files
                  3.store data in structured text files(xml,html)
                  4.Excnahge Data with a database via FlashVars/Xml
                  It all depends what the endgame is.
                  Working with XML is pretty much  a standard with most webservices:
                  http://help.adobe.com/en_US/as3/dev/WS5b3ccc516d4fbf351e63e3d118a9b90204-7ff5.html
                  LSO, textfiles and FlashVars are easier to work with, but not suited for complex/large data
                  http://help.adobe.com/en_US/FlashPlatform/reference/actionscript/3/flash/net/SharedObject. html
                  http://help.adobe.com/en_US/as3/dev/WS5b3ccc516d4fbf351e63e3d118a9b90204-7cf8.html
                  the moment you want to store data on a server you will have to use sth like asp or php in addition to as3.
                  If you have no experience in using these webtechnologies  expect a steep learning curve
                  • 6. Re: How to link swf to database asp
                    Many thanks.
                    I'll keep that in mind of course.
                    And also many thanks  for cooperating with all the silly doubts I might be giving.
                    And for all the links you are providing.
                    • 7. Re: How to link swf to database asp
                      Hello again.
                      I have so far come to this. Is it relevant to the output which I want?
                      submit.addEventListener(MouseEvent.CLICK, sendData);
                      function sendData(event:MouseEvent):void
                        var urlreq:URLRequest = new URLRequest ("http://www.mydomain.com/file.asp");
                        urlreq.method = URLRequestMethod.POST;
                        var urlvars:URLVariables = new URLVariables();
                      /* urlvars.uname = nametxt.text;
                        urlvars.apellido = aptxt.text;
                        urlvars.email = emtxt.text;
                        urlvars.cedula = cctxt.text;
                        urlvars.score = scoretxt.text;*/
                        urlreq.data = urlvars;
                        var loader:URLLoader = new URLLoader (urlreq);
                        loader.addEventListener(Event.COMPLETE, completed);
                        loader.dataFormat = URLLoaderDataFormat.VARIABLES;
                        loader.load(urlreq);
                      function completed (event:Event):void
                        var variables:URLVariables = new URLVariables( event.target.data );
                        //resptxt.text = variables.done;
                      Here instead of this .text area, what should I do to get movieclip instances.
                      That is the selected movieclip instances at every runtime  has to be get in a .txt file or a databse file.
                      What is the changes to do in Flash file to acheive this. i.e. index the mc's or creating arrays or something.
                      If any other suggestions, Please help.
                      Thank u in advance.
