1. Re: multiple offset paths / outlines with defined offset?
Jacob Bugge Sep 27, 2013 9:10 AM (in response to laden.m)laden.m,
Is repeating the offset out of the question?
On a Win Machine, you may press Alt+O+P+O (hold Alt and press O then P then O), then the set value and press Enter. After that, you can just repeat the Alt+O+P+O for each new offset.
2. Re: multiple offset paths / outlines with defined offset?
laden.m Sep 27, 2013 12:08 PM (in response to Jacob Bugge)hi jacob,
thanks, but i'm on a mac and the shortcut you gave me isn't working. but i suppose you mean the "offset path" effect?
this is not working for me because i need more than 100 multiple paths.
i need something where i can give the distance or the number af offset paths.
the blend tool could do this, but it is messing too much with the original shape of the mask.
i need the look of the offset path filter but with the functionality of the blend tool?
here an example:
3. Re: multiple offset paths / outlines with defined offset?
Kurt Gold Sep 27, 2013 12:26 PM (in response to laden.m)Have you tried a graphic style consisting of multiple strokes to which the Offset Path effect is applied?
It's a bit time-consuming to set up the graphic style, but once it is done you can reuse it with a single click.
4. Re: multiple offset paths / outlines with defined offset?
JETalmage Sep 28, 2013 7:41 AM (in response to laden.m)The feature you're needing is a contour command/tool which is common in other drawing programs but missing in Illustrator:
Corel Draw:
Xara Designer Pro has a similar interactive feature:
Everything in Illustrator is a workaround.
Cumbersome workarounds are possible, but don't match the ease, features (ex: accelleration), or after-the-fact adjustability of a proper contour feature:
You should be able to do a dumb (non-adjustable) workaround by repeatedly applying Offset Path. However, a few versions ago Illustrator's Offset Path command was wrecked by a change which leaves both the original and the new path selected. You can work around that by building an Action which "names" and "un-names" the original each time so that it can be targeted by the Set Selection step. The Action does the following:
1. Sets a Note in the Attributes palette to temporarily flag the selected path as "Original."
2. Performs the Offset Path command.
3. Sets the selection to the path labeled "Original" (thereby deselecting the offset path).
4. Clears the selected path's note (so it is no longer labeled "Original").
5. Selects the Next Object Below (which is the offset path).
After recording the Action, it can be run by repeatedly clicking the Run button. Each time, it offsets a path by the same distance.
Illustrator Workaround; Offset Path Action:
Of course the above results in just a set of dumb unrelated paths, so there is no after-the-fact adjustability that automatically updates. You can have some live adjustability by using a Blend between two identical paths which both have Offset Path applied as an Effect, but with different offset distance parameters:
Illustrator Workaround; Offset Path Effect Blend:
Tolerable, but still doesn't match the capabilities of a proper contour feature:
JET
