1. Re: How to use the line tool? (changing the line thickness)
Ann Bens Sep 29, 2013 7:21 AM (in response to hollanditus)Dit is het forum voor Premiere Pro.
A moderator will come along soon and move it to the proper forum.
2. Re: How to use the line tool? (changing the line thickness)
John T Smith Sep 29, 2013 7:34 AM (in response to hollanditus)Correct forum is http://forums.adobe.com/community/premiere_elements
3. Re: How to use the line tool? (changing the line thickness)
JSS1138 Sep 29, 2013 9:38 AM (in response to hollanditus)[Moved to Elements forum.]
4. Re: How to use the line tool? (changing the line thickness)
Bill Hunt Sep 29, 2013 10:03 AM (in response to JSS1138)Thank you Jim.
Titus,
First, and especially for the arrows, this article might be useful: http://forums.adobe.com/message/3702803#3702803
Another method of "highlighting and object/subject," can be found here: http://forums.adobe.com/message/3199543#3199543
Now, in the Titler (the Title editor), Shapes (the Line is but one), one makes changes with Styles, which are demonstrated with Text (the most common usage), but can be applied to Shapes, as well. Personally, I find this method to be, well, a bit kludgey, and not 100% intuitive. That is why I linked to the above articles.
Also, for intricate Shapes, I find that Photoshop (both Elements and it's "big-brother," Photoshop) to be easier and more powerful, when creating Titles. One would just create a New Image, with a Transparent Background, and then use the Tools in Ps, to get exactly what I want. That Image would be Saved_As a PSD, to be Imported into Premiere Elements.
Good luck, and let us know if that is helpful to you.
5. Re: How to use the line tool? (changing the line thickness)
A.T. Romano Sep 29, 2013 2:02 PM (in response to hollanditus)hollanditus
If you did want to pursue the Titler/Shape Section/Line Tool, you might explore and experiment with drawing your line with the
Shape's Line Tool, applying a Style to the line, and then using Color Properties to fill in the styled-line with a solid color. Interesting effects possible.
http://www.atr935.blogspot.com/2013/08/pe11-titler-shapes-for-highlighting.html
http://www.atr935.blogspot.com/2013/07/pe-titler-part-2-styles.html
ATR
