1 Reply Latest reply on Sep 30, 2013 10:33 AM by try67
    tallying check marks
    mseverns23
      I have an evaluation form where I need to tally up the total amount of boxes that are checked in given columns.   So for example I have a column with boxes named 1.1U, 1.2U, 1.3U, & 1.4U, and an over all rating box 1Utotal.  Is there a script that can look at the four boxes and then produce a number for how many of them are checked?
        • 1. Re: tallying check marks
          You can use something like this as a doc-level script:
          function countCheckBoxes(names) {
               var total = 0;
               for (var i in names) {
                    var f = this.getField(names[i]);
                    if (f.value!="Off") total++;
               return total;
          And then in your total field you use this code as the custom calculation script:
          event.value = countCheckBoxes(["1.1U", "1.2U", "1.3U", "1.4U"]);
