4 Replies Latest reply on Oct 5, 2013 11:58 AM by Markpic
    Burning DVD's
      My avi.file is about 16gb. How can I burn it on to one 4.7gb DVD, or if not how can I burn it onto a succession of DVd's (say3)?
        • 1. Re: Burning DVD's
          The Tutorial Links Page http://forums.adobe.com/thread/1275830 has a link for Sharing to a DVD that may help
          Your AVI file will be compressed to MPEG/VOB to go on a DVD... I'm not sure if 16Gig will compress that far and still be above the minimum data rate
          • 2. Re: Burning DVD's
            A.T. Romano Level 7
            What version of Premiere Elements are you using and on what computer operaing system is it running?
            Just what do you want to do?
            Burn an .avi file to a DVD disc as an .avi file?
            Burn a Premiere Elements Timeline containing this .avi file to the format of DVD-VIDEO on DVD disc?
            For now, I will assume the latter.
            Preliminary test to get a baseline for strategy...
            1. If you can, import your .avi file into Premiere Elements project with project preset selected to match the properties of your source media.
            2. Place a DVD-R into the DVD burner tray.
            3. Go to the sharing area of your Premiere Elements, select ..../Disc/DVD disc, in the burn dialog, what does it say in the Quality Area for Space Required and Bitrate? Get those values for with and without a check mark next to the option "Fit Contents to Available Space".
            What type of DVD disc do you have?
            DVD 4.7 GB/120 minutes (in reality 4.7 = 4.38 GB)
            DVD 8.5 GB/240 minutes (in reality 8.5 = 7.95 GB)
            Let us start here and then decide what next.
            • 3. Re: Burning DVD's
              the_wine_snob Level 9
              Along with the answers to the questions posed above, I have one more, please:
              What is the Duration of your Timeline?
              When one authors a DVD-Video, the Timeline is Encoded to MPEG-2 DVD, which is a compressed format. The resulting file(s) will be compressed to a smaller size. How much compression is needed, and even possible, will be shown by the Duration of that Timeline. From that information, others can recommend either a "quality setting," or perhaps suggest that you use a DVD-9 (8.5), in lieu of a DVD-5 (4.7) in very general terms - see ATR's Reply #2 for exact capacities.
              • 4. Re: Burning DVD's
                Markpic Level 1
                DVD-video (as it is actually known)
                Can maintain high quality playback using mpeg-2 compression.
                The 4.7 GB blank disk can most times hold...just 4.1 GB's.
                When my camcorder was a DV-tape camcorder--I made 50-minute long video's to hold quality at its best.
                I would push that to 1-hour 10-minutes if absolutely necessary.
                At 1-hour 20-minutes...the video quality will be less.
                Your DV-avi File should be 13-GB's MAX.
                While 11.5 GB's is best.
                Next to consider is a Dual Layer DVD-blank.
                Which requires DL format playback machines.
                Blu-ray solves all of those problems.
                But also requires a Blu-ray playback machine.
                When using DV-tape...I just made 50-minute lenght projects.
                Adding multiple disk--projects.
                Message was edited by: Markpic
