1 Reply Latest reply on Oct 4, 2013 1:12 AM by Lilybiri
    risizing pictures in Slide Show editor doesn't work
    CopyCheck
      Hello,
      resizing pictures in the Image Slide show rizise/crop menu editor doesn't have any effect
      on the pictures after press OK button.
      The other features like brightness, sharpness do have effect
      Captivate 6
      Image Slide show project
      Windows 7
        • 1. Re: risizing pictures in Slide Show editor doesn't work
          Lilybiri MVP & Adobe Community Professional
          Hello,
          Indeed, you cannot use resizing. I rarely use that kind of project and if I would I certainly will make sure that all images have the same total resolution which is normally the case when you prepare a slideshow.
          Workaround: create a normal project, import all the images to the Library and drag them to the slides; since they will not be merged into the slide immediately you'll be able to use all the functionality of Image Edit accordion.
          Lilybiri
