• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
2 .cpd files in same project--a problem?
Guest
Oct 01, 2013 Oct 01, 2013
I am working on a large Robohelp 7 HTML project (3,280 files in db), that was cloned from an existing project.  Whenever I open it, it hangs at "Loading DB Info..." for an hour or more.  It's CPU Usage swells to 50-60% of CPU capacity, and the Memory Usage will stay bloated at 185MB (vs. about 4MB for the old source project)
Also, when I "Save All" the first time each day, it hangs up for an hour or two.  After that, "Save All" (and everything else) functions normally...
I notice that the cloned project now has 2 .cpd files (and 2 corresponding .brs files)--a normal-sized one (4MB) carrying the old source project's name, and another humonguous .cpd file (85MB) with the new cloned project's name.  Could this be a symptom or cause of my opening and saving problems?
Views
494
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
The bloated CPD may very well be causing a slow project. You can safely delete the CPD files (RoboHelp will create a new one when you reopen the project.)
If you want to be sure, make a backup of the CPD files just as a precaution.
Greet,
Willam
Votes
Translate
Translate
Report
Report
LEGEND ,
Just to add to what Willam has said, can you tell us what you mean by "cloned". I ask because it is not normal to have two of any project file in the same directory. Whilst deleting the CPD files may solve this issue, I wonder if you'll get other issues further down the line.
Votes
Translate
Translate
Report
Report
Guest
"Cloned" isn't a very good description...  I created the new project by copying the entire DB of the old source project, then renamed the new project.
Votes
Translate
Translate
Report
Report
Community Expert ,
Oct 02, 2013 Oct 02, 2013
Define DB. You can create a new project by copying the whole project but if you are only copying parts nothing would surprise me.
@petergrainge
Votes
Translate
Translate
Report
Report
Guest
Oct 07, 2013 Oct 07, 2013
LATEST
Peter,
Thanks for the help… I had copied an entire project—I was leary of just copying parts.
Deleting the .cpd files fixed all of my problems it seems…
Cheers,
Jamie
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
