4 Replies Latest reply on Oct 5, 2013 1:46 PM by the_wine_snob
    ATI TECHNOLOGIES
    ricfeupmag1990 Level 1
      Boa tarde,
      Tenho a programa - Adobe Premiere Elements 10 mas tem a problema. A mensagem disse "Exibir detalhes do drive: ATI Technologies Inc. - ATI Mobility Radeon HD 4250 Graphics - 3.0.9910 Compatibility Profile Context". Não consegui resolver isso. Algumas pessoas podem ajudar-me?
      Muito obrigado,
        • 1. Re: ATI TECHNOLOGIES
          andaleebfatima1 Adobe Employee
          When do you see this problem? Also, you will get a better answer for your issue on PRE Forums - http://forums.adobe.com/community/premiere_elements
          Andaleeb
          • 2. Re: ATI TECHNOLOGIES
            the_wine_snob Level 9
            Google Translate from Portuguese:
            Good afternoon,
            I have a program - Adobe Premiere Elements 10 but has the problem. The message said "View details drive: ATI Technologies Inc. - ATI Mobility Radeon HD 4250 Graphics - 3.0.9910 Compatibility Profile Context". I could not solve it. Some people can help me?
            Thank you,
            My reply in English:
            Welcome to the forum.
            It appears that you have an issue with your AMD/ATI Radeon graphics card's video driver.
            If that translation is correct, then go to the AMD/ATI Web site, plug in your graphics card's model, plus your OS, then download and install the latest driver.
            In Portuguese:
            Bem-vindo ao fórum.
            Parece que você tem um problema com o driver de vídeo da sua placa de vídeo Radeon da AMD / ATI.
            Se a tradução estiver correta, então vá para o site da AMD / ATI, conecte o modelo de sua placa de vídeo, além de seu sistema operacional, faça o download e instalar o driver mais recente.
            Boa sorte,
            • 3. Re: ATI TECHNOLOGIES
              Markpic Level 1
              You are using a laptop PC.
              You need to get your driver's from the laptop--manufacturer.
              ATI/AMD can not be of any service--for a laptop.
              Also--many laptop's use a 5400-rpm HDD for system C:/drive.
              In all my experiance (2003).
              All your HDD's must be 7200-rpm.
              (for video projects of any kind)
              Message was edited by: Markpic
              • 4. Re: ATI TECHNOLOGIES
                Markpic,
                While that is often correct, I have two laptops, both with nVidia video chips, that accept the drivers from nVidia. One is a Sager and the other is an ADK, and both with Clevo MoBo's.
                Back with my Toshiba Satellite, I DID have use the Toshiba nVidia drivers - or create my own. Straight nVidia drivers would NOT install, without a rewrite.
