2 Replies Latest reply on Oct 2, 2013 11:22 AM by tordenver
    Speed/Duration...
    tordenver Level 1
      Is there a way to display the Speed/Duration percentage in a column? I did a search in the metadata display with no luck... so I am guessing it is not part of the metadata :-(
      Also could someone explain to me what is the idea of having two similar functions SPEED/DURATION and TIME REMAPPING? I understand Time Remapping is more powerful in the sense you can keyframe your time speed and change it overtime. So then why implement the Speed/Duration function which is to affect a whole clip duration? it appears there is no link between these two functions.
      I am in the process to conform a program so that I can color grade it in Resolve: Time Remapping clip do not translate via FCP XML, where as Speed/Duration will, if the clip was correctly setup for your sequence frame rate.
      Thank you,
      David
