3 Replies Latest reply on Oct 3, 2013 4:47 AM by Inno78 Branched from an earlier discussion.
    Import rendering mov = Crash
    Inno78
      Same problem here but in Premiere CC. Premiere crashes when importing a MOV.
      Please solve this issue ASAP!
        • 1. Re: Import rendering mov = Crash
          Jim_Simon Level 8
          This is just a user forum.  We can't actually do anything about Premiere Pro's code.  The official bug report form is below.
          https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
          • 2. Re: Import rendering mov = Crash
            Codec & Format information, with 2 links inside to read
            -read both links in reply #1 http://forums.adobe.com/thread/1270588
            Report back with the codec details of your file, use the programs below... A screen shot works well to SHOW people what you are doing
            http://forums.adobe.com/thread/592070?tstart=30
            For PC http://mediainfo.sourceforge.net/en or http://www.headbands.com/gspot/
            For Mac http://mediainspector.massanti.com/
            • 3. Re: Import rendering mov = Crash
              Inno78 Level 1
              What I do is actually easy. I drag and drop the movie from Finder into Premiere. It appears in the list and as soon as Premiere opens it (automatically) in the source panel, it crashes.
              This is the requested information:
              General
              Complete name                    : /Users/i_replaced_this/Documents/GA2_8967.MOV
              Format                           : MPEG-4
              Format profile                   : QuickTime
              Codec ID                         : qt
              File size                        : 531 MiB
              Duration                         : 3mn 21s
              Overall bit rate                 : 22.1 Mbps
              Encoded date                     : UTC 2013-09-22 18:42:47
              Tagged date                      : UTC 2013-10-02 11:59:19
              NCDT                             : NCTG
              Video
              Format                           : AVC
              Format/Info                      : Advanced Video Codec
              Format profile                   : High@L4.0
              Format settings, CABAC           : Yes
              Format settings, ReFrames        : 2 frames
              Format settings, GOP             : M=3, N=15
              Codec ID                         : avc1
              Codec ID/Info                    : Advanced Video Coding
              Duration                         : 3mn 21s
              Bit rate mode                    : Variable
              Bit rate                         : 20.6 Mbps
              Width                            : 1 920 pixels
              Height                           : 1 080 pixels
              Display aspect ratio             : 16:9
              Frame rate mode                  : Constant
              Frame rate                       : 29.970 fps
              Color space                      : YUV
              Chroma subsampling               : 4:2:0
              Bit depth                        : 8 bits
              Scan type                        : Progressive
              Bits/(Pixel*Frame)               : 0.331
              Stream size                      : 494 MiB (93%)
              Language                         : English
              Tagged date                      : UTC 2013-09-22 18:42:47
              Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
              Transfer characteristics         : BT.470-6 System M, NTSC, FTC 73.682, BT.1700 625 PAL, BT.1700 625 SECAM
              Matrix coefficients              : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
              Audio
              Format                           : PCM
              Format settings, Endianness      : Little
              Format settings, Sign            : Signed
              Codec ID                         : sowt
              Duration                         : 3mn 21s
              Bit rate mode                    : Constant
              Bit rate                         : 1 536 Kbps
              Channel(s)                       : 2 channels
              Sampling rate                    : 48.0 KHz
              Bit depth                        : 16 bits
              Stream size                      : 36.9 MiB (7%)
              Language                         : English
