0 Replies Latest reply on Oct 2, 2013 9:41 AM by DaveOHare01
    CFThread Corruption Issue
    DaveOHare01
      I've recently starting using cfthread on one of my CF 9 servers.   I've seen some wildly odd behaviour from the threads and am wondering if this is a known issue.
      I am grabbing a set of data which is 1200 rows deep.  I loop over that data 12 times, grab 100 rows each time and create a unique thread.   If I don't artificially add delay the query distribution between the threads is random and weighted heavily towards the last thread created.   Even after adding 5-6 seconds of delay between spawning new threads – the distribution is not level.   The ONLY time I can get 100 rows per thread is when I insert a cfdump of the query (adding a LOT of additional processing time).
      Im writing the thread names into my table for debug purposes - so I can get an exact count of which thread is processing which numbers.
      Here is the distribution after adding 5-6 seconds of delay for a set of 100:
      threadtest COUNT(`threadtest`)
      MigThread1 21
      MigThread2 51
      MigThread3 28
      -- as you can see, though the data set passed into each thread is distinct, is seems to be handed to the threads in a random way -- as if the thread attributes and scopes were immediately corrupted.   Oddly, I always get the number of rows processed that I want - just not distributed between the threads as I expect.
      Here is the code:
      <!---get the data --->
      <cfquery name="getTNs" datasource="xxxx">
                      SELECT SubKey, TN, LRN, MAC, CLLI, StagingFallout, FinalFallout
          FROM MigValidationNew
          WHERE JobKey = '#JobKey#' AND StagingFallout <> '1'
      </cfquery>
      <!--- Build a new dataset so the threads are better controlled --->
      <cfset SortedTNs = querynew("IndexCounter, TN, SubKey")>
                      <cfset RowCounter = '1'>
                      <cfoutput query="getTNs">
                      <cfset QueryAddRow(SortedTNs)>
                                       <cfset QuerySetCell(SortedTNs,"IndexCounter",#RowCounter#)>
                                      <cfset QuerySetCell(SortedTNs,"TN",#TN#)>
                                      <cfset QuerySetCell(SortedTNs,"SubKey",#SubKey#)>
                                      <cfset RowCounter = #RowCounter# + 1>
                      </cfoutput>
      <!--- Set the number of threads by dividing the total TNs returned by n --->
      <cfset numGroups = 50>
      <cfset MigrationRounds = Ceiling(RowCounter / numGroups )>
      <!--- Loop over the record set, creating n threads each with n TNs --->
      <cfloop index="loopindex" from="1" to="#MigrationRounds#">
      <!--- Ensure a unique thread name --->
                      <cfset threadName = "MigThread#loopindex#">
                      <cfif #loopindex# EQ 1>
                                      <cfset startNumber = #loopindex#>
                      <cfelse>
                                      <cfset startNumber = ((#loopindex# - 1) * numGroups) + 1>
                      </cfif>
                      <cfset endNumber = #loopindex# * numGroups>
                                      <cfquery name="getSubset" dbtype="query">
                      SELECT IndexCounter, TN, SubKey
              FROM SortedTNs
              WHERE IndexCounter >= #startNumber# AND IndexCounter <= #endNumber#
                      </cfquery>
      <cfoutput><p>#threadName# St: #startNumber#  En: #endNumber# RecordCount is #getSubset.RecordCount#</p></cfoutput>
                      <cfthread
              name="#threadName#"
              action="run"
              priority="HIGH">
                                      <cfoutput query="getSubset">
                  <!--- Update the database with the thread name--->
                  <cfquery name="updateTN" datasource="xxx">
                      Update MigValidationNew
                      SET threadtest = '#threadName#'
                      WHERE SubKey = '#SubKey#'
                  </cfquery>
                      </cfoutput>
      </cfthread>
      <!--- Add delay between the threads to limit the corruption--->
      <cfloop index="InternalIdx" from="1" to="3000000" step="1"> </cfloop>
      <p>Next Thread!</p>
      </cfloop>
      <!--- Rejoin the threads for the display --->
      <cfthread action="join" timeout="299999"/>
