Expand my Community achievements bar.
Dive into Adobe Summit 2024! Explore curated list of AEM sessions & labs, register, connect with experts, ask questions, engage, and share insights. Don't miss the excitement.
SOLVED
PDF generator failure ALC-DSC-002-000
Avatar
Former Community Member
PDF generator watched folder is failing with ALC-DSC-002-000 error code. However I can convert using create pdf option. Please advise.
Error details:
Failure Time----Thu Oct 03 13:48:11 IST 2013
source location ---- Reason of failure is-----Parameter: inputDocument is required.
ALC-DSC-002-000: com.adobe.idp.dsc.RequiredParameterException: Parameter: inputDocument is required.
          at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:117)
          at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
          at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
          at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTransactionBMTAdapterBean.java:197)
          at sun.reflect.GeneratedMethodAccessor597.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.jboss.invocation.Invocation.performCall(Invocation.java:386)
          at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionContainer.java:233)
          at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionInterceptor.java:156)
          at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
          at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
          at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:173)
          at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
          at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstanceInterceptor.java:173)
          at org.jboss.ejb.plugins.SecurityInterceptor.process(SecurityInterceptor.java:228)
          at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:211)
          at org.jboss.ejb.plugins.security.PreSecurityInterceptor.process(PreSecurityInterceptor.java:97)
          at org.jboss.ejb.plugins.security.PreSecurityInterceptor.invoke(PreSecurityInterceptor.java:81)
          at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
          at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor.java:138)
          at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:650)
          at org.jboss.ejb.Container.invoke(Container.java:1092)
          at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:436)
          at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
          at $Proxy260.doBMT(Unknown Source)
          at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:95)
          at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
          at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
          at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
          at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:188)
          at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
          at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
          at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:131)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:93)
          at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:225)
          at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:69)
          at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
          at com.adobe.idp.jobmanager.execution.workadapter.AbstractExecutableJob.invokeRequest(AbstractExecutableJob.java:127)
          at com.adobe.idp.jobmanager.execution.workadapter.PersistentExecutableJob.execute(PersistentExecutableJob.java:60)
          at com.adobe.idp.dsc.workmanager.adapter.UnManagedAsynchronousWorkAdapter.run(UnManagedAsynchronousWorkAdapter.java:39)
          at org.jboss.resource.work.WorkWrapper.execute(WorkWrapper.java:205)
          at org.jboss.util.threadpool.BasicTaskWrapper.run(BasicTaskWrapper.java:260)
          at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
          at java.lang.Thread.run(Thread.java:662)
1 Accepted Solution
Avatar
Correct answer by
Level 3
It seems that you have not given proper input/output parameter mappings:
Verify your watch folder settings as mentioned here -http://help.adobe.com/en_US/livecycle/9.0/adminHelp/admin.htm?content=000106.html
Also see "Using a watched folder start point" @ http://www.adobe.com/devnet/livecycle/videotraining.html
~ Varun
View solution in original post
Avatar
Correct answer by
Level 3
~ Varun
Avatar
Hi Varun,
Issue resolved. Thank you.
Sandaruwan
