5 Replies Latest reply on Oct 3, 2013 12:14 PM by goodnewsmagazine
    Help
    goodnewsmagazine
      Hello. I need to know how to duplicate an old Indesign document, rename it, move it to another folder, but keep all the pictures linked? Can you please help?
      Thanks!
        • 1. Re: Help
          John Mensinger Adobe Community Professional & MVP
          There are a few different ways to go about such things. Here's one:
          Open the file, and choose File > Save As to save it under a different name in a different location. This will keep links intact so long as the original linked files stay put.
          If storage space isn't a concern, you could replicate the linked file set using File > Package to save copies of the file and all its linked files in a new folder. There is also a way to copy-and-migrate the linked files via the Links panel.
          • 2. Re: Help
            goodnewsmagazine Level 1
            Thanks for the quick response...will have to try your ideas...thanks again.
            • 3. Re: Help
              and what if I do want to clean up a few things and put some of the linked
              files into different folders -- but all within the same folder?  Any way to
              keep them linked?
              • 4. Re: Help
                If you change the path to a linked file, you break the link.
                It sounds like you want to reorganize the linked files by adding a new folder level. Obviously, that's best done before links are established. What you're asking would require some re-linking afterward. Later versions of InDesign will find additional previously-linked files in a folder when an initial re-link is performed, so you wouldn't have to re-link each file; just one per new folder.
                • 5. Re: Help
                  Okay - thanks for all your help. I was afraid that there was no easy way to
                  re-organize my files...
                  But thanks so much.
                  Patti
