1. Re: Cropping isn't changing the document size
Noel Carboni Oct 3, 2013 7:43 AM (in response to Heirloom Bob)Photoshop will select whatever tool you last left selected when you last closed Photoshop.
There have been changes, which not everyone agrees are for the better, in the Crop Tool. At the very least they take some re-learning before one gets used to how they work.
Chances are, the Crop Tool is changing your ppi value so that the result of the crop is coming out 36 x 24 because you don't have the size values set properly in the Options Bar fields. Can you take a screenshot of the settings you have there while the Crop Tool is selected?
These values, for example, could yield the result you want...
-Noel
2. Re: Cropping isn't changing the document size
Heirloom Bob Oct 3, 2013 8:30 AM (in response to Noel Carboni) -
3. Re: Cropping isn't changing the document size
Heirloom Bob Oct 3, 2013 8:35 AM (in response to Heirloom Bob)Stupid of me Noel...just solved the issue. Had ratio selected instead of w x h x res.
Thanks for your help.
4. Re: Cropping isn't changing the document size
Noel Carboni Oct 3, 2013 11:12 AM (in response to Heirloom Bob)No worries, there are a lot of things that combine.
Keep in mind one other thing: Your image won't be resampled to a particular ppi resolution if you leave the res field blank, and just put in 18.5 in and 12.5 in.
-Noel
