I purchased the Macromedia Suite a few years ago and today I installed everything on a new laptop, but when I try to open Flash I get a message stating...
"Flash 6.0 r25 has stopped working"
I am given two options
1. Check online for a solution and close the program
2. Close the program
The problem details are listed as...
Problem Event Name: APPCRASH
Allication Name: Flash.exe
Application Version: 6.0 r25.0
Application Timestamp: 3c88582e
Fault Module Name: ntdll,dll
Fault Module Version: 6.17601.18229
Fauld Module Timestamp: 51fb1072
Exception Code: c0000005
Exception Offset: 0002e066
OS Version: 6.1.7601.2.0.768.3
LocaleID: 1033
Additional Information 1: c3a6
Additional Information 2: c3a6e12b3471cf0446336182f39020f9
Additional Information 3: a542
Additional Information 4: a542c57554703160958dddc65ff4e5ac
I know this version is probably ancient history by know, but it is what I have to work with. I eagerly await your assistance.
The probability of being able to use Flash 6 on a new operating system is likely next to zero. If you can find an ancient machine (An XP system should work) you might stand a better chance of getting it working.
Thank you for the reply. I actually stumbled upon a solution myself and want to make this information available to any other poor boys like me. I found a Troubleshoot Compatibility option in a Program Data Options Window. When I ran the troubleshooter, it indicated that my current Windows program had a color issue and needed to revert to a color option of a prior Windows version. It made mention of Windows XP Service Pack 2. It said that it would run Flash 6.0 on the older colors and return to Aero when I closed the program. I hope this helps somebody in the future,
