1 Reply Latest reply on Oct 4, 2013 7:34 AM by gkaiseril
    NotAllowedError: Security settings prevent access to this property or method.
    Sumith20051979
      While calling a SOAP method to send PDF document stream, I am getting NotAllowedError: Security settings prevent access to this property or method. error. I am able to connect to webservices successfully and able to get data from that. But while trying to send data from adobe acrobat 9 pro to webservice using Javascript, I am getting this error.
      I have given the sample code which I am using.
      //Function which I am calling from a menu click
      var convertToXMl = app.trustedFunction(function() {
      app.beginPriv();
      try {
      var adocs=app.activeDocs;
      var curDoc=adocs[0];
           curDoc.saveAs("/C/Temp/adobe/abc_tmp.xml","com.adobe.acrobat.xml-1-00");
      } catch (e) {
           app.alert("An error occured during saving! " + e);
      var service=SOAP.connect("http://localhost:92/Service1.svc?wsdl");
      var documentStream = Collab.documentToStream(curDoc);
      var encodedStream = Net.streamEncode(documentStream, "base64");
      var utfencodedStream = util.stringFromStream(encodedStream, "utf-8");
      var base64String = {soapType: "xsd:string",soapValue: utfencodedStream};
      var result = service.SaveMyDoc({docStream:base64String}); // Getting NotAllowedError on this line
      app.endPriv();
      My Webservices (C#.NET) code looks like this.
      public void SaveMyDoc(string docStream)
      if (docStream.Length > 0)
      string path = @"C://Temp1//adobe_save_files";
      try
      byte[] pdf = Convert.FromBase64String(docStream);
           File.WriteAllBytes(path + "//mydoc.pdf", pdf);
      catch (Exception ex)
      throw ex;
      Please help me on this as I am very new in adobe acrobat Javascript programming. It would be great if anyone can give sample code also to achieve this.
